Heads - Mustang Evolution
Old 06-10-2012, 10:39 AM   #1
Thrasher13's Avatar
Heads
I'm looking into different heads but I don't know which to go with. Whatever I go with I'm planning to have ported polished and shaved. What would be the best heads with work done to them. Factory e7 heads, 351w heads, or a set or gt40p heads.
Thrasher13 is offline   Reply With Quote
Old 06-10-2012, 05:12 PM   #2
gt40p are the best you listed. but none would compare to a good set of aluminum heads.
Old 06-10-2012, 06:28 PM   #3
aegischief's Avatar
If you are going to go through the trouble of porting get some good aluminum heads. Plus, they will perform better than the heads you listed right out of the box. If you look around a set of twisted wedge, edlebrock or Holley heads can be found for cheap. I bought a set of twisted wedge heads a few years ago complete for $600.
aegischief is offline   Reply With Quote
Old 06-10-2012, 07:34 PM   #4
Re: Heads
I agree 100%.
Save the money you would spend on those heads and look for a used set of aluminum heads.
You will not only get a better flowing set of heads, but you will remove some weight from the front of the car.
Old 06-11-2012, 08:28 AM   #5
aegischief's Avatar
Originally Posted by Trojan Horse
I agree 100%.
+1
Old 06-11-2012, 02:19 PM   #6
Go aluminum. I spent a lot of money porting and installing new valves in an old set of gt40's only to find out they were cracked. Finally got some afr 165's.
2003GtVert is offline   Reply With Quote
10:29 PM
