95 mustang GT - Mustang Evolution
Old 06-12-2012, 03:55 PM   #1
NickMac's Avatar
95 mustang GT
Just took off my 70mm bbk throttle body and put the stck throttle body back on with a new idle air control and TPS to fix and idle issue. Now the car will turn over but will not start. Any suggestions on where to start
NickMac is offline   Reply With Quote
Old 06-12-2012, 06:16 PM   #2
the tps and iac are both new?
did you check the schrader valve to see if there is fuel there? with the vacuum unplugged there should be around 38-40 lbs
this is pretty strange. you made sure all connections are tight?
the only other thing i can suggest is try putting the other parts back on one at a time until to see which part is the problem.
maybe someone else will have had similar problems and will chime in.
Old 06-14-2012, 08:15 PM   #3
your ecu might have needed to relearn its parameters.
07:08 PM
