06-12-2012, 09:04 PM
#1 | | Registered User
| Tear down complete
Took me 6 hours but it's tore down. Exhaust gone. And whole top end off tomorrow is cleaning time and hopefully install new cam and lifters so I can order my new push rods
__________________ |
06-12-2012, 09:05 PM
#2 | | Senior Member
| Re: Tear down complete
Moar Powuh FTW!
06-12-2012, 09:14 PM
#3 | | Senior Member
Sweet. Awsome man
#4 | | Filibuster
Awesome!..
06-13-2012, 06:41 AM
#5 | | Registered User
How come you didn't pull it out? & what all are you doing any aftermarket heads
06-13-2012, 06:55 AM
#6 | | Moderator
Good to see you gettin it done, need to hurry so we can see what it'll do at the track.
06-13-2012, 07:53 AM
#7 | | Registered User
Yeah it would have been easier out of the car
06-13-2012, 01:48 PM
#8 | | Registered User
Garbill I'm doin HCI swap with new exhaust.
All bottom in is good everything looks nice and clean cylinder walls are clean. Bout to go back in with new cam. Then call it a day cause I leave for two weeks in morning. Got all the inner finders cleaned up all gaskets off ready to put the rest on. And found out I have a triple X block don't know of all mustangs came with them but mine has one
06-13-2012, 02:02 PM
#9 | | Senior Member
Xxx just means roller block. It is the most common.
06-13-2012, 02:08 PM
#10 | | Registered User
Ok didn't know that
06-13-2012, 05:27 PM
#11 | | Registered User
I have one heco in mexico 302 block I have I ve read that they are a good block
06-13-2012, 08:12 PM
#12 | | Registered User
Well all is put on hold the F'ed up my cam and I have to send it back and get another one. 1st put cam in and timing gear bolt is to small. So easy fix right I went and got another bolt grade 8. That fits. Put cam back in and the dail pin that goes through top timing gear is about half inch to long it goes all the way through gear and hitting washer not allowing the bolt to seat proper. Grrrrr. This all took place at 5:15 this afternoon so the cam company "cam motion" is closed they will here it tomorrow
06-13-2012, 08:19 PM
#13 | | Senior Member
Weird, did they send you a flat tappet camshaft I wonder?
06-13-2012, 08:20 PM
#14 | | Senior Member
that really sucks man! sorry im not familiar with cam motion. is that the name of the cam or just manufacturer? hopefully they take care of you, besides the fact they delayed the project!
06-13-2012, 08:46 PM
#15 | | Registered User
Idk TH idk. Cam motion is a company out of baton rouge the custom grinds cams. Yea I hope they do fix it. It's either fix it or give me my money back so I can call comp. and next question I can't get it on my phone. But I checked my pushrods length and I need a 6 3/8 in pushrod hardened for guide plates if anyone can find them and post and link. It would be helpful thanks in advance
06-13-2012, 08:52 PM
#16 | | Senior Member
they are a bit pricey. http://www.summitracing.com/parts/CRN-36625-16/ ---------- Post added at 09:52 PM ---------- Previous post was at 09:51 PM ---------- i checked jegs and summit. they both had the same ones for the same price.
06-13-2012, 09:24 PM
#17 | | Registered User
Thanks
06-14-2012, 10:19 AM
#18 | | Registered User
Ok talked to cam company. They did increase size of timing bolt for strength and the dowl pin is one for the fuel pump that goes in to timing cover so they said either grind down pin or cut notch in washer
