AC help - Mustang Evolution
Old 06-13-2012, 05:32 PM   #1
deadsp0t's Avatar
AC help
Ok as explained before in another thread, my AC only comes out of the defrost and floor vents and will not switch to the dash vents. As suggested in the other threads I've pulled the AC controls and glove box and confirmed that the red, white, blue, black and yellow all are intact and attached.
I can reach in and move the flap inside the vent tunnel and the air blows out of the dash vents but stay open..
Experience? Suggestions? Thanks guys.
That's unimpressive
Old 06-13-2012, 05:34 PM   #2
I haven't messed with them personally. But I do know that the vents are vacuum controlled. I would track down the vacuum lines and see if one is disconnected.
Old 06-13-2012, 05:36 PM   #3
deadsp0t's Avatar
There are two I can not see the end of. They leave the controls into a block then out again behind the vent tunnel can't see where they go
That's unimpressive
Old 06-13-2012, 05:40 PM   #4
maybe these will help?
ID:	54620   Click image for larger version
Old 06-13-2012, 05:47 PM   #5
deadsp0t's Avatar
Looks like maybe the vent/defrost vacuum motor
That's unimpressive
Old 06-13-2012, 05:50 PM   #6
i wonder if you could take it off and clean it up? or at least inspect it for wear or failure.
Old 06-13-2012, 05:59 PM   #7
deadsp0t's Avatar
There is no vacuum there or at the other one behind the glove box. Looking at the second pic I'm wondering if the issue is no vacuum from the engine compartment.
That's unimpressive
Old 06-13-2012, 06:03 PM   #8
93slowstang's Avatar
Have you checked at the vacuum tree?
Old 06-13-2012, 06:14 PM   #9
i think its gonna be in the area of what slowsatng says. the vacuum lines have a rubber coating on them. you may have to peel of the rubber, (if it has it) to inspect the lines.
http://www.allfordmustangs.com/forum...ol-issues.html
Old 06-13-2012, 07:18 PM   #10
deadsp0t's Avatar
The hard line from the tree to the coupling was broken at both ends.. Rather then reuse the fittings and line I went and got a new hard line and fitting.. Works great now! Thanks for the help guys!
That's unimpressive
Old 06-13-2012, 07:19 PM   #11
Your welcome. Glad you got it taken care of.
Old 06-13-2012, 07:23 PM   #12
deadsp0t's Avatar
that second pic made troubleshooting it back to the engine compartment then to the tree fairly easy! Took longer to put the dash parts I didn't need to remove back then it took to replace the line lol
That's unimpressive
Old 06-13-2012, 07:30 PM   #13
Glad you got it fixed.
08:24 AM
