e cam Q - Mustang Evolution
Old 06-13-2012, 05:48 PM   #1
mystang50's Avatar
e cam Q
Do you lose bottom end power with a e cam?? Cuz feels bad compared to stocck cam
Old 06-13-2012, 06:06 PM   #2
93slowstang's Avatar
Pretty much, mine doesn't really pick up till about 2k rpms.
Old 06-13-2012, 06:11 PM   #3
Newline's Avatar
Is the car an auto or stick. What gears and intake
Newline is offline   Reply With Quote
Old 06-13-2012, 06:26 PM   #4
Manual with 2.73 gears, explorer gt40 intake and gt40p heads. Don't get m wrong though my car pulls harder overall but down low isn't as good as the stock cam. Gears would help tremendously with that problem.
Old 06-13-2012, 07:36 PM   #5
Newline's Avatar
Set base time around 10 or 11 degrees and see how it feels. You should feel a nice peppy off idle pull
Old 06-13-2012, 07:42 PM   #6
Mine felt more like a dog off the line at 10*, I played around and found that mine worked best at 14*.
Old 06-13-2012, 07:43 PM   #7
Newline's Avatar
Quick question where do u live
Old 06-13-2012, 07:45 PM   #8
Me?
Old 06-13-2012, 07:53 PM   #9
Newline's Avatar
Yeah if u are in a high altitude it's different and also what plugs are in the heads
Old 06-13-2012, 08:22 PM   #10
Louisiana, an I'm running ngk iridium plugs at the moment.
Old 06-13-2012, 11:28 PM   #11
mystang50's Avatar
Ok mine is auto, 2100 stall, ported typhoon intake, 373 gears...Jus feels sluggish on bottomvend...my timing is set after cam for spray, so I can't add timing
Old 06-14-2012, 07:50 AM   #12
A little bigger stall would help a lot. If you look on ford racing it should say the recommended stall to use. But I would guess in the 2500-2800.
Also the typhoon is an ok intake for stock to real mild. But you may gain some low end torque back with a better intake. It would also help to port and polish it. The typhoon has real bad casting flash in it.
Old 06-14-2012, 09:59 PM   #13
mystang50's Avatar
It's allready been ported
Old 06-15-2012, 06:28 AM   #14
Newline's Avatar
You could use the old 1.6 intake 1.7 exhaust move
Old 06-16-2012, 12:21 PM   #15
mystang50's Avatar
Could you explain that plza
Old 06-16-2012, 12:31 PM   #16
I think what he is saying.
The reason you lose low end torque is because you have more air coming in than going out. So adding the 1.7 on exhaust will let more exhaust out, keeping the intake the same. Honestly imo if you plan of further upgrading, then I would deal with it till then. Instead of buying rr's twice, and hoping that it will work.A lot of people do what he suggested on forced induction motors.
Old 06-16-2012, 01:13 PM   #17
Stang.racr's Avatar
Gears is killing your car with that cam. I had your same set up and I was highly pissed after spending 500 bucks and doing a test drive. It felt like I lost twenty hp
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 06-16-2012, 01:21 PM   #18
Gears are killing the cam? don't they recommend using a higher gear ratio with cam?
Old 06-16-2012, 01:39 PM   #19
That's what I was always told. They are supposed to help keep you in the power band...
Old 06-16-2012, 03:16 PM   #20
91gt's Avatar
I got and e cam and I have 410s and mine pulls hard
91gt is offline   Reply With Quote
Old 06-17-2012, 01:04 AM   #21
mystang50's Avatar
I got 373's
Old 06-17-2012, 07:50 AM   #22
Stang.racr's Avatar
Bigger cams need a higher gear ad a higher torque converter for autos to stay in the correct rpm range/ power band. Think about it this away. A taller cam can have a 2500-6500 power band. If you are running a 2.73-3.55 gears then you would need to always keep a lower gear to be in your rpm range.
---------- Post added at 06:50 AM ---------- Previous post was at 06:40 AM ----------
Sorry, I had the same set up as 93slowstang. That's what I meant referring to loosing a lot of low end.
Old 06-17-2012, 10:06 AM   #23
Lol gotcha, yeah I know thats why mine was so noticeable. My gear selection is on hold till I figure out what I'm going to do, im thinking of going turbo soon.
Old 06-17-2012, 11:38 AM   #24
Stang.racr's Avatar
My stock cam and stock geared car run 14.6s on a 275/60 tire (28 inches) I added a e cam and 26 inch tires and no change in my et or trap. I lost ALOT of bottem end. I should of gained .2 tenths alone just by switching to a 26" tire on that car. I got the cam for free( my old car) paid 150 ish for trick flow beehive valve springs, 100 ish for a new time chain, 80 ish for a gasket set, 100ish for arp head bolts, 120 for heads to get freshened up yada yada yada. In total I spent in the 500 range for a car to sound better lol
Old 06-19-2012, 11:07 AM   #25
mystang50's Avatar
Well bad news bout that intake...its alum. So with the heat it expandsled and contracted backed my two top intake bolts out and striped the threads on the intake, gota tap them and rethered them. It was bad!!lasted a week with it on there
Old 06-19-2012, 04:11 PM   #26
Stang.racr's Avatar
Sucks man
Old 06-20-2012, 12:02 AM   #27
Re: e cam Q
If you are talking about a Typhoon intake, they are made in China and prone to failing from what I have read about them.
Pick up a Cobra intake and have it ported by Tmoss Porting. You will be much happier with the intake and the performance.
08:41 PM
