06-13-2012, 08:36 PM
#1 | | Registered User
| Oil ?
89 mustang gt 5.0 engine has work done to it. What oil do you recommend? About to do the first oil change in it since I have had it
06-13-2012, 09:32 PM
#2 | | Registered User
If your willing to fork out the money royal purple is really good. Like I said though its kind of expensive. That or mobil 1 synthetic isn't bad. What mods do you have?
06-13-2012, 10:39 PM
#3 | | Registered User
Hooker headers bbk cold air intake it's cammed but I dont know what one. 4.10 gears dual Flowmaster x.
06-14-2012, 04:33 PM
#4 | | Registered User
I always play it safe and stick with motorcraft.. And I've never felt safe putting synthetics in a older motor..
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
06-14-2012, 08:46 PM
#5 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac I always play it safe and stick with motorcraft.. And I've never felt safe putting synthetics in a older motor.. | They won't hurt a thing and from what I have recently read, the issue of synthetic oils causing leaks is no longer a problem. Note, that I have not verified this myself though.
__________________ |
06-14-2012, 10:57 PM
#6 | | Registered User
| Quote: |
Originally Posted by Trojan Horse
They won't hurt a thing and from what I have recently read, the issue of synthetic oils causing leaks is no longer a problem. Note, that I have not verified this myself though.  | What do you use in your cars?
06-15-2012, 12:27 AM
#7 | | Registered User
| 1989 mustang royal purple 10w30 is doing good in my engine
06-15-2012, 12:53 AM
#8 | | Registered User
I had no idea what the guy before
Me had in the car but when I got home I put motorcraft in it because it was low. But I just wanted to get ideas from people before I choose what I'm gonna change it to
06-15-2012, 09:12 AM
#9 | | Registered User
Valvoline is what I run 10-30
06-15-2012, 10:27 AM
#10 | | Registered User
| Quote: |
What do you use in your cars? | Royal purple I what I run...when I have some Pocket change lol
06-15-2012, 10:35 AM
#11 | | Registered User
| Re: Oil ?
I use mobile 1 10w40
06-15-2012, 10:38 AM
#12 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac What do you use in your cars? | Motorcraft Semi-Synthetic & Mobil 1.
06-15-2012, 11:36 AM
#13 | | Registered User
| Quote: |
Motorcraft Semi-Synthetic & Mobil 1. | Do you use Mobil 1 in your newer cars or? And what weight do you run in your 5.0
06-15-2012, 11:45 AM
#14 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac Do you use Mobil 1 in your newer cars or? And what weight do you run in your 5.0 | I use the Motorcraft Semi-Synthetic 5W/20 in my newest car and the Mobil 1, 5W/30 in my 5.0.
06-15-2012, 11:52 AM
#15 | | Registered User
In my 90 mustang I use motorcraft 5w30 I believe motorcraft is synthetic blend as opposed to full synthetic. I was running motorcraft full synthetic but I have a oil pan gasket leak an have to add a quart or so between oil changes. When I redo this engine or build another( not sure yet) im gonna go full synthetic again
06-15-2012, 11:58 AM
#16 | | Registered User
| Quote: |
I use the Motorcraft Semi-Synthetic 5W/20 in my newest car and the Mobil 1, 5W/30 in my 5.0. | What you think about using mobil 1 in my 5.0 with 130k ---------- Post added at 12:58 PM ---------- Previous post was at 12:52 PM ---------- Don't think I'm going to.. I was deciding on wether to use 5w or 10w -30 and I was thinking I might switch to synthetic in my 2001 v6 with 80k miles. But I'm a little sceptic. And does motorcraft make a full synthetic?
06-15-2012, 12:18 PM
#17 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac What you think about using mobil 1 in my 5.0 with 130k ---------- Post added at 12:58 PM ---------- Previous post was at 12:52 PM ---------- Don't think I'm going to.. I was deciding on wether to use 5w or 10w -30 and I was thinking I might switch to synthetic in my 2001 v6 with 80k miles. But I'm a little sceptic. And does motorcraft make a full synthetic? | I think it would be ok and either 5w or 10w/30 would work.
If you live farther North where it gets colder, I would run the 5w, farther South where it stays warmer then the 10w would be my choice.
Yes, Motorcraft makes a full synthetic. - Motorcraft Oils
Synthetic oils have been proven to reduce friction and increase HP and mileage.
06-15-2012, 01:11 PM
#18 | | Registered User
| Quote: |
Synthetic oils have been proven to reduce friction and increase HP and mileage. | Well I'm in Nebraska hot then hell summers with cold as ice winters. Ill probable use 5w-30 motorcraft full synthetic (if I can find it) on my v6 and synthetic blend on my 5.0. ---------- Post added at 02:11 PM ---------- Previous post was at 02:07 PM ---------- Quote: |
Synthetic oils have been proven to reduce friction and increase HP and mileage. | Now for my 5.0 I'm sticking with 5w30 but should I switch to 5w20 for my v6?
06-15-2012, 01:15 PM
#19 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac Now for my 5.0 I'm sticking with 5w30 but should I switch to 5w20 for my v6? | Not unless it calls for it in your owners manual or on an engine/engine bay sticker.
06-15-2012, 01:21 PM
#20 | | Registered User
| Quote: |
Not unless it calls for it in your owners manual or on an engine/engine bay sticker. | Well every time you go someware all the new books say use 5w20 and that stupid thing at Walmart but my owners Manuel says 5w30..
06-15-2012, 01:28 PM
#21 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by sixpac Well every time you go someware all the new books say use 5w20 and that stupid thing at Walmart but my owners Manuel says 5w30.. | Stick with what the owner's manual says.
Going as thin as possible with your engine oil will reduce the rotating force required somewhat, but the thinner oil will not provide the film strength needed for your engine unless it has been designed to use the thinner oils. Ford knows what is best for your engine. After all, they designed and built it.
06-15-2012, 01:32 PM
#22 | | Registered User
| Quote: |
Going as thin as possible with your engine oil will reduce the rotating force required somewhat, but the thinner oil will not provide the film strength needed for your engine unless it has been designed to use the thinner oils. Ford knows what is best for your engine. After all, they designed and built it.  | Well that is why I have always sticked with motorcraft in all my fords.. I figured them guys who designed it are getting payed a lot more then I am or probably ever will so the should know what there talking about. So ill probably go with 5w-30 for both cars but full synthetic for my v6.
06-15-2012, 01:58 PM
#23 | | Registered User
Does it mater if you have mods done to the engine? Should I use 10w30 or 5 or synthetic
06-15-2012, 07:50 PM
#24 | | Senior Member
A blend is and if the guy who built the motor did it right wide ope throttle at first he did I a favor gets all the shaving and burs out the first run ,best way to to do it . U idle it u just can scorch it . Best way no matter what any one says
06-15-2012, 07:59 PM
#25 | | Evolution's Finest
| Quote: |
Originally Posted by sixpac I always play it safe and stick with motorcraft.. And I've never felt safe putting synthetics in a older motor.. | I put Penzoil synthetic in my 87 GT a few years back and she bled all over the place. I had to dump it and put regular 10W40 back in but it took 3 oil changes before it stopped the bleeding. Horrible, cause she wasn't even leaking at all before I used it.
06-15-2012, 10:31 PM
#26 | | Registered User
I think I'll just stick to a good rand of 10w30
06-16-2012, 03:11 AM
#27 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by Azure I put Penzoil synthetic in my 87 GT a few years back and she bled all over the place. I had to dump it and put regular 10W40 back in but it took 3 oil changes before it stopped the bleeding. Horrible, cause she wasn't even leaking at all before I used it.  | If they do that, then you really need to replace the seals. The only thing sealing it up is the dirt and debris left by conventional oils and you really don't want that stuff floating around in your engine oiling system.
Supposedly from what I read, at least some synthetic manufacturers have reformulated to keep that from happening. Of course that means that all of the gunk the synthetics used to clean out gets left in your engine now.
In most cases there are only 2 seals affected. The front timing chain cover seal and the rear main seal. If they and any other gaskets do start leaking, then you had a problem there to begin with and the seals or gaskets should be replaced anyways.
06-16-2012, 03:58 AM
#28 | | Registered User
| Re: Oil ?
I use 5w30 Castrol Edge in my Pony 09 and RP in my 98 Villager van.
2009 Candy Apple Red V6 PP/ Security package
2012 Candy Apple Metallic 3.7 Charcoal interior/AP
J&M adj. panhard bar/BMR Lca's/ Boss 302 Strut brace
Badges/ blackout rear deck/blackout third tail Mustang
SR Performance rear springs/Whiteline brackets
06-16-2012, 05:51 AM
#29 | | Registered User
I run ams oil in everything i own and swear by it! Run it in both my bikes my dad runs it in his 71 chevelle, his harley, **** even the lawn mowers and power washer lol it works amazing!
06-16-2012, 06:24 AM
#30 | | Senior Member
| Re: Oil ? Quote:
Originally Posted by Blackbeauty95 I run ams oil in everything i own and swear by it! Run it in both my bikes my dad runs it in his 71 chevelle, his harley, **** even the lawn mowers and power washer lol it works amazing! | I have seen the Amsoil ads, but its lack of easy availability in my area has kept me from having much interest in trying it. The main reason I use the Mobil 1, is that I can stop by the local auto parts store and pick it up. For me the real test is whenever I tear down an engine and get a good look at the internals after running any brand of oil. You can really tell which brands are better by the condition, cleanliness and wear that way.
Another lesser known brand in my area is Schaeffer's Specialized Lubricants.
My cousin who has had numerous high HP vehicles (1000 to 1400+ HP) swears by their products and uses them exclusively.
06-16-2012, 06:37 AM
#31 | | Evolution's Finest
| Quote: |
In most cases there are only 2 seals affected. The front timing chain cover seal and the rear main seal. If they and any other gaskets do start leaking, then you had a problem there to begin with and the seals or gaskets should be replaced anyways. | I believe my rear main was just getting started before I tried the synthetic oil, so maybe it was destined to happen
When I put Royal Purple in my current Mustang, I had some anxiety for a few days waiting to see if it was going to start leaking. Fortunately, no probs  I hope that fancy oil filter is catching some of the debris!
06-16-2012, 06:38 AM
#32 | | Registered User
I usually stick with castrol 10-30 in my 90 GT but mainly cause I'm a force fan. An castrol never let me down. But after my mods I'm thinking hard about royal purple
#33 | | Evolution's Finest
| Quote: |
Originally Posted by Blackbeauty95 I run ams oil in everything i own and swear by it! Run it in both my bikes my dad runs it in his 71 chevelle, his harley, **** even the lawn mowers and power washer lol it works amazing! | I didn't think about the lawn mower! I bought a new one last summer, so I think I'm gonna do that
06-16-2012, 06:42 AM
#34 | | Evolution's Finest
| Quote: |
Originally Posted by captain78 I usually stick with castrol 10-30 in my 90 GT but mainly cause I'm a force fan. An castrol never let me down. But after my mods I'm thinking hard about royal purple | I live in the neighborhood right next to his facility in Indiana. Here's me and the Force...
06-16-2012, 06:53 AM
#35 | | Registered User
If my scanner was working i would be able to send you guys all the paper work i have on royal purple its really not that good of an oil and breaks down extremely fast
