Oil coming threw pvc valve - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-14-2012, 02:25 PM   #1
Chefnick's Avatar
Chefnick is unknown around these parts
A lot of oil coming up threw the PVC valve. Any clue in why this would happen
Chefnick is offline
Old 06-14-2012, 02:27 PM   #2
Senior Member
Trojan Horse is just getting started.
Re: Oil coming threw pvc valve
Piston rings worn out causing excessive blow by, or the screen and valve need replacing.
Trojan Horse is offline
Old 06-14-2012, 02:28 PM   #3
Storm13_5.0's Avatar
Storm13_5.0 is unknown around these parts
Try a new PVC valve
Storm13_5.0 is offline
Old 06-14-2012, 03:27 PM   #4
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
AMDanBailer is unknown around these parts
Chefnick,
Oil can come through the PCV Valve. I would recommend replacing the PCV Valve and getting a oil catch can to start!
In most cases its normal, if there is A LOT of oil then it could be time for valve seals & rings.
I would try a new PCV and a Oil Catch Can before I ripped apart the motor(that should at least control the oil). This is just my opinion!
I hope this helps!
Hit me up if you have any questions!
- Dan
AMDanBailer is offline
Old 06-15-2012, 10:48 PM   #5
Chefnick's Avatar
When I say a lot..... I mean as in like a poured a few cups worth out of my intake once
I took it off. Also when I took off the lower intake a plug cam out of a hole that I think supplys oil to the pushrods? Should that that plug be pressed in? It is basically right below where the PVc
Screen. Thanks
Chefnick is offline
Old 06-16-2012, 02:51 AM   #6
Senior Member
Screen. Thanks
Well that's not right for sure.
Can you get us a picture of the hole and plug so we can be sure of what you are talking about?
Old 06-16-2012, 09:13 PM   #7
5.8GT's Avatar
5.8GT is unknown around these parts
Mine was doing the sane thing, come to find out I had forgotten to put the screen under the pcv valve. I will pull a lot of oil through the valve if the screen is bad or missing.
5.8GT is offline
Closed Thread
03:31 PM
