back with fuel problems again - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-14-2012, 06:09 PM   #1
ebourd is unknown around these parts
Smile back with fuel problems again
so i changed fuel pump and all relays this is my second fuel pump but pressure is dropping to 20 or less psi any help is welcome 92 ford mustang GT 5.0
ebourd is offline
Old 06-14-2012, 06:55 PM   #2
Senior Member
dreamstang is unknown around these parts
thats a wierd problem. hmmmm....
does this happen gradually? how long between pump changes?
are the pumps autozon/ebay specials?
dreamstang is offline
Old 06-14-2012, 06:56 PM   #3
deadsp0t's Avatar
deadsp0t is unknown around these parts
Regulator?
That's unimpressive
deadsp0t is offline
Old 06-14-2012, 06:57 PM   #4
Re: back with fuel problems again
this pump has been in there almost two weeks and yes autozone been fine till today my buddy suggested trying a higher amp fuel pump relay
ebourd is offline
Old 06-14-2012, 07:03 PM   #5
Senior Member
are you getting 20 lbs at the scrader or the rails? if you can check both, that will help eliminate the regulator as dead suggests.
what brand pump is it? i would try to get a walbro at least.
Old 06-14-2012, 07:06 PM   #6
not sure what brand and yeah 20lb or less at rails ill check before regulator
ebourd is offline
Old 06-14-2012, 08:43 PM   #7
Senior Member
Trojan Horse is just getting started.
I agree with the regulator being a possibility.
Also ensure the filter is good and not clogged up.
You may also have one or more injectors sticking open.
Notice any black smoke or stumbling when you start it?
Trojan Horse is offline
Old 06-15-2012, 01:56 AM   #8
no to the black smoke and got a bbk adjustable pressure reg hope it works going in morning
ebourd is offline
Old 06-15-2012, 06:00 PM   #9
Ok bbk and newer injectors on used but a lot less mileage then mine see what happens
ebourd is offline
Old 06-18-2012, 05:57 PM   #10
Ok well guys it did it again Idk what else to try my buddy suggested higher amp fuel and ac relay I'm stump I have changed everything
ebourd is offline
Old 06-18-2012, 08:57 PM   #11
anyone got any ideas
ebourd is offline
Old 06-18-2012, 09:03 PM   #12
Senior Member
check the tfi module. im not positive it can do this. but i think it can. there should be a testing procedure in haynes/chilton.
---------- Post added at 10:03 PM ---------- Previous post was at 10:00 PM ----------
also did you check pressure at the schrader valve just to see? that will gurantee if you pump is pumping properly of not.
Old 06-18-2012, 09:03 PM   #13
tfi ? not sure what that is but im willing to try anything
ebourd is offline
Old 06-18-2012, 09:04 PM   #14
Senior Member
tfi module aka igniton module. its mounted on the side of the distributor. it tells the ecu when to turn the pump on. it also has other functions to.
Old 06-18-2012, 09:09 PM   #15
wont go over twenty psi when its angry and added the bbk pressure reg are u talking about ignition module i already change that along with relays coil dam near anything any one has said try
ebourd is offline
Old 06-18-2012, 09:13 PM   #16
Senior Member
before you changes parts that we suggest you can test them first. almost all those parts are testable.
i hate to say it but if you cant get over 20 lbs before the regulator. you either got a bunk pump or have a clogged filter or kinked line.
once this problem occurs does it stay like that? or is it intermittent?
Old 06-18-2012, 09:20 PM   #17
intermittent it will go for a few days fine and then in the heat of the evening it does it and i believe its the return side for the pressure at 20 psi
---------- Post added at 08:20 PM ---------- Previous post was at 08:17 PM ----------
it also was doing it with last pump
seems like when it cools it works again
ebourd is offline
Old 06-18-2012, 09:24 PM   #18
Senior Member
What do you mean return side? The pressure on the return doesn't matter.
Do you have rubber line on the return? If so try linking it and seeing if your pressure raises. If it doesn't then the pump isn't doing its job, I think.
Next time this happens you need to check voltage at the pump. It sound like to me that your losing voltage somehow at the pump intermittently. You may have to trace that down with a meter. But you will only be able to find the problem when it occurs, most likely.
Old 06-18-2012, 09:33 PM   #19
here is pressure gauge
ebourd is offline
Old 06-18-2012, 09:37 PM   #20
Senior Member
I can't tell what line its on. But its hard to tell in the pic. But you have 35-38 lbs at that time? Must be when its running right?
Old 06-18-2012, 10:25 PM   #21
yeah 35-40 when running correctly
ebourd is offline
Old 06-19-2012, 01:17 PM   #22
Anyone with ideas
ebourd is offline
Old 06-19-2012, 05:44 PM   #23
Pete Jones
90mustangLX's Avatar
90mustangLX is unknown around these parts
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Did you try to clean the tank before installing the new pump? I know on the advance and auto zone pumps there's a little screen on the pump itself and they always get clogged and end up choking/burning the pumps up. My 87 did something similar to this. It would drive fine then out of the blue if you stabbed the throttle it would just pop and crack lie it was starving for fuel.
Checked the pressure when it did this and at idle ur was around 40 psi, nail the throttle and bam down to 10 lbs of pressure. Turned out the little screen was clogged and was causing the pump to overheat. Put a new one in and it fixed it.
90 LX 5spd swap Stock 302 GT40P heads
BBK shorties and h-pipe
flowmaster 40's dumped, Jegs Big n Littles
BBK CAI, BBK SSI-R upper and lower
Professional Products 75mm TB,Electric Fan
MSD 8.5 90 degree plug wires
90mustangLX is offline
Old 06-19-2012, 05:55 PM   #24
Senior Member
You maybe on to something.
Old 06-19-2012, 06:40 PM   #25
sixpac's Avatar
sixpac is unknown around these parts
Long shot but have you checked your timing? My bronco had a problem and we adjusted the timing and then didn't have a priblem
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
sixpac is offline
Old 06-25-2012, 11:14 AM   #26
So here's an update voltage at pump drops to around ten volts when it happens can't seem to find the cause though
ebourd is offline
Old 06-25-2012, 11:35 AM   #27
Senior Member
Did you check voltage at the before and after the relay also? That will help determine the spot your losing voltage.
And its been a while. Did you say you checked ignition(tfi) module and pip(hall) sensor?
Also check voltage on the battery when it happens. Whatever the alternator/battery are putting out, is all the whole system will have.
Old 06-25-2012, 07:08 PM   #28
Senior Member
May be that the filter sock on the fuel pump in the tank (like 90mustangLX said) is collapsing from being plugged up.If there are no wiring problems, then that is likely the cause.
I bet if you had an ammeter on the pump it would jump way up when that happens.
Old 07-05-2012, 08:16 PM   #29
Hey trojan need ur help I ran another wire even put a switch for fuel its been working fine all week and today it died again like a block from my house gonna change filter again then I guess its back to the third pump fuel isn't coming up to twenty psi right now
---------- Post added at 07:16 PM ---------- Previous post was at 06:42 PM ----------
Or anyone really
ebourd is offline
Old 07-06-2012, 12:25 AM   #30
Senior Member
Or anyone really
Did you check the fuel sock in the tank? Filter?
How about the pressure regulator, checked or replaced?
You must be picking up some debris or have some bad wiring or grounds if it is killing pumps.
Clean the tank good while you have it out and make sure you get a new sock with the pump.
Old 07-06-2012, 11:40 AM   #31
Sock is clean pressure reg is new ran new wires tank is spotless guess I'm just headed back to pump
ebourd is offline
Old 07-06-2012, 11:45 AM   #32
Pete Jones
What's it look like on the under side of the pump with the sock off?
Old 07-06-2012, 11:58 AM   #33
Brand new pump same as last one
ebourd is offline
Old 07-06-2012, 03:51 PM   #34
Just want to thank everyone for the help
ebourd is offline
Closed Thread
01:07 AM
