MSD - Mustang Evolution
Old 06-14-2012, 06:18 PM   #1
Ricksta's Avatar
Region: New Hampshire
MSD
Just Got an 86 GT with a 91 engine. Was vacuuming and found these under the dash. How do I now if there hooked up and if there working properly.
ID:	54767   Click image for larger version
ID:	54769   Click image for larger version
Ricksta is offline   Reply With Quote
Old 06-14-2012, 06:48 PM   #2
youmcan test the big red wire for 12 volts. you can also unplug the big red and see if you have voltage. as tfor the rev controller, try to rev it past 5800.
---------- Post added at 07:48 PM ---------- Previous post was at 07:42 PM ----------
sorry, i just realized. i think the rev control works through the box. so just rev it and see what happens
Old 06-14-2012, 06:56 PM   #3
Ricksta's Avatar
Ya the rev control is pluged into the other msd box by a 4 wire plug. Do u now what the black box is. No name on it. What should happen at 5800 rpm. Thanks for ur help
---------- Post added at 06:56 PM ---------- Previous post was at 06:54 PM ----------
Seem like you and TH now your stuff about stangs. Appreciate ur help
Old 06-14-2012, 07:00 PM   #4
i havent personally used the soft touch rev control. but the black box is hooked to the rev control right? the 5800 is just a pill that is used to set the rpm limit. when you hit that limit the msd will automatically skip certain sparks to control the rpm. you can get pill kits at jegs and summit to adjust the limit. my msd box has it built in. but i havent bought any pills yet.
---------- Post added at 08:00 PM ---------- Previous post was at 07:59 PM ----------
thanx man! no problem.
Old 06-14-2012, 07:05 PM   #5
Ricksta's Avatar
Ok. I'll check that tomorrow. I take it I should keep this for future upgrades
Old 06-14-2012, 07:13 PM   #6
absolutley. the stuff you have is good for all level of builds.
its always nice to find a suprise like that!
Old 06-14-2012, 07:15 PM   #7
Ricksta's Avatar
Ya it was a surprise. Thanks for all your help.
Old 06-14-2012, 07:16 PM   #8
your welcome.
Old 06-14-2012, 07:35 PM   #9
Ricksta's Avatar
I take it you guys don't live in New England
Old 06-14-2012, 07:41 PM   #10
I live in Indiana.
Old 06-14-2012, 08:30 PM   #11
Re: MSD
And I live in MO.
When you have time use the model numbers off of the MSD components that have them and go to the MSD website. There you will find owner's manuals, instructions and wiring diagrams in case you ever need them.
That black box could be an RPM activated switch, two step or other MSD add on module. Hard to say without any numbers to check.
Old 06-15-2012, 03:27 AM   #12
Ricksta's Avatar
Wow. You are out there. Thanks for all your help
10:50 AM
