86 gt won't start with key, but starts with solenoid jumped - Mustang Evolution
Old 06-15-2012, 04:50 PM   #1
lilrafe87's Avatar
Was starting fine, but went to start it just a bit ago and it cranked for a split second and would not start again with the key. Jumped the solenoid and car starts right up. Just won't start with key. Any suggestions?
lilrafe87 is offline   Reply With Quote
Old 06-15-2012, 05:01 PM   #2
Gibby's Avatar
Try not letting the key spring back after you turn it. Sometime an old ignition will aping the key back to far and not let you start your vehicle.
Turn key when vehicle sounds like it starts turn the key back to run manually....
Gibby is offline   Reply With Quote
Old 06-15-2012, 05:49 PM   #3
lilrafe87's Avatar
It won't start at all. Tried that. even let the pedal up n down while key is turned. I know it's not the starter. I'm guessing it's the clutch switch.
Old 06-15-2012, 05:52 PM   #4
Gibby's Avatar
Yea that was my next guess. Just route the two wires together and eliminate the switch...
Old 06-15-2012, 05:56 PM   #5
lilrafe87's Avatar
I'll try it now, get back with ya in min
Old 06-15-2012, 05:58 PM   #6
Gibby's Avatar
Alright good luck
Old 06-15-2012, 07:13 PM   #7
lilrafe87's Avatar
Figured out out. It was the battery cable that connects to the solenoid. It was a little loose on the solenoid. Didn't feel loose, but it turned a good full turn. Thanks for your help.
Old 06-15-2012, 07:17 PM   #8
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
If you ever think its the neutral safety switch don't cut the wires and twist them together. Just unplug them and throw in a 20 or 25 amp fuse into both plugs by the clutch pedal. That will bypass the switch altogether then you don't have to worry about splicing the plug back on if you ever decided to fix the switch if it was bad.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-15-2012, 07:52 PM   #9
lilrafe87's Avatar
Ok, thanx
Old 06-18-2012, 12:43 AM   #10
lilrafe87's Avatar
Only thing I need to do is change a ball joint and do the brakes and she is ready for the summer.
Old 06-18-2012, 01:43 AM   #11
Blackbeauty95's Avatar
I'm gonna just twist them together because i like being able to start my car without having to push in the clutch pedal
Blackbeauty95 is offline   Reply With Quote
Old 06-18-2012, 04:21 AM   #12
Re: 86 gt won't start with key, but starts with solenoid jumped
Yeah, right up until you forget to push in the clutch or take it out of gear some day and jump it into another car or something.
I wouldn't do that, because the something may be a person or small child.
Old 06-18-2012, 04:36 AM   #13
True true
Old 06-18-2012, 04:46 AM   #14
My car doesn't have neutral safety switch. I just push the clutch in anyways to be safe. It's habbit. Plus my escort is a 5 speed. So I don't forget cause I have to do it in there.
11:46 AM
