06-16-2012, 12:08 AM
#1 | | Registered User
| Cooling prob
Y mustang seems to continuely gets warmer the longer i sit at idle. As long ad im driving its fine just cant sit att idle to long. I have replaced all hoses thermostat water pump radiator fan can not get it stop geting hot when its warm out. Any help would b greatly appreciated
06-16-2012, 12:48 AM
#2 | | Registered User
| Re: Cooling prob
Check to see if your radiator fan is kicking on
1995 Cammed/Turboed V6 Mustang (auto)
13.3@103mph
Built by Iron Horse Motorsports
06-16-2012, 12:51 AM
#3 | | Registered User
Its a clutch fan and its bran new ---------- Post added at 01:50 AM ---------- Previous post was at 01:49 AM ---------- Its a 89 mustang saleen ---------- Post added at 01:51 AM ---------- Previous post was at 01:50 AM ---------- I even took to my freinds smog shop and used his sniffer to check for hc in radiator to make sure wasnt head gasket and its fine
06-16-2012, 12:54 AM
#4 | | Registered User
| Re: Cooling prob
Ahh ok...
What degree is your thermostat?
13.3@103mph
06-16-2012, 12:59 AM
#5 | | Registered User
It has 180 in it now but no matter what thermo i put in its runs fine till u sit and idle then it just keeps getn warm soon as i start drivn it will cool back down ---------- Post added at 01:59 AM ---------- Previous post was at 01:58 AM ---------- Im at a loss. If i had hair id b pulling it out haha
06-16-2012, 01:09 AM
#6 | | Registered User
| Re: Cooling prob
Lol, is your coolant level good?
13.3@103mph
06-16-2012, 01:12 AM
#7 | | Registered User
Yes
06-16-2012, 01:14 AM
#8 | | Registered User
Radiator needing to be flushed?
Coolant correct 50% / 50% mix?
Water pump worn out and not moving enough fluid?
If it is when it's idling and not moving, then I'm leading toward some kind of airflow issue.
Is the fan clutch engaging when it's hot (raise the idle speed and you should hear the sound of the fan engaged)?
Just some thoughts
Paul
06-16-2012, 01:18 AM
#9 | | Registered User
Thanks yes clutch fan and waterpump are new ---------- Post added at 02:18 AM ---------- Previous post was at 02:18 AM ---------- Flushed radiator and coolant is 50/50
06-16-2012, 01:20 AM
#10 | | Registered User
How hot is it getting?
06-16-2012, 01:27 AM
#11 | | Registered User
Not sure exactly its stock gage but it get to high end of normal on gage and ill shut it down unless im driving then it cool as i get goin. Enough to were it starts runing like ****
06-16-2012, 01:34 AM
#12 | | Registered User
Have you changed the drive belt?
If not, I would, if you have, take off the belt and scuff up the water pump pulley. It may be slipping and not spinning the water pump/fan pulley fast enough when the clutch is engaged.
06-16-2012, 02:05 AM
#13 | | Registered User
Ill give it a shot willing to try anything. Hadnt tought of that ---------- Post added at 03:04 AM ---------- Previous post was at 03:03 AM ---------- And yes its a new drive belt ---------- Post added at 03:05 AM ---------- Previous post was at 03:04 AM ---------- Should i use some sandpaper
06-16-2012, 02:09 AM
#14 | | Registered User
Somehow I think you are not getting enough air though the radiator at slow speed. When you drive the vehicle faster that air is forced through the radiator by the speed of the vehicle, slow speeds is when you need that extra help sucking air through.
Good luck
06-16-2012, 02:10 AM
#15 | | Registered User
Thanks
#16 | | Registered User
Sand paper, emery cloth, steel wool. Just something to scuff the surface of the pulley when the belt contacts it.
06-16-2012, 03:28 AM
#17 | | Senior Member
| Re: Cooling prob
Is your belt on so it turns the water pump in the correct direction?Has the water pump been replaced and is it the correct one?
5.0 HO water pumps turn backwards compared to other Ford engines.
If you have the wrong one installed or it is not being turned in the correct direction you will definitely have heating issues.
__________________ |
06-16-2012, 10:47 AM
#18 | | Registered User
Yes i am sure its the right pump and is turning the right direction.
06-16-2012, 12:01 PM
#19 | | Registered User
So the fan is supposed to engage at idle and slip at highh speed correct?
06-16-2012, 03:40 PM
#20 | | Registered User
I am having the exact same prob. At idle it will reach over 200 and then I shut it off. At cruising speed I am at 180.
06-16-2012, 03:49 PM
#21 | | Registered User
Its driving me crazy. I have replaced everything water pump radiator hoses sensor clutchfan thermo nothing helps im loosing my mind
06-16-2012, 03:53 PM
#22 | | Moderator Emeritus
| Quote: |
Originally Posted by Kenny laird Its driving me crazy. I have replaced everything water pump radiator hoses sensor clutchfan thermo nothing helps im loosing my mind | Maybe the problem is with the sending unit or the gauge it self.. Have you tried an aftermarket gauge to confirm the temp your seeing is correct?
That's unimpressive
06-16-2012, 04:24 PM
#23 | | Registered User
No i wouldnt think it would b wrong only at idle. And i know its hot couse it start runin like crap ---------- Post added at 05:24 PM ---------- Previous post was at 05:16 PM ---------- If its not hot outside it will sit at 180 all day long
06-16-2012, 06:47 PM
#24 | | Senior Member
I think its the radiator. If your fins are bent you won't get proper air flow through them. Or it could be filmed up inside. I would try flushing it out real good and then straightening the fins if they are bent.
06-16-2012, 11:02 PM
#25 | | Registered User
Thanks but i have dine it. Even moved up to a 3 row radiator
06-16-2012, 11:34 PM
#26 | | Moderator Emeritus
Thermostat can be in backwards.. Also could have an air pocket in the system likely in the intake at the highest point. It can show the symptoms. They can be a pain to get out and they can cook an engine.
That's unimpressive
06-17-2012, 12:38 AM
#27 | | Registered User
I have let run with cap off to get air out but if there is a air pocket how do i get it out ---------- Post added at 01:38 AM ---------- Previous post was at 01:36 AM ---------- Now im thinkn about that. Spring side in block right?
06-17-2012, 02:19 AM
#28 | | Senior Member
| Re: Cooling prob Quote:
Originally Posted by Travis B I am having the exact same prob. At idle it will reach over 200 and then I shut it off. At cruising speed I am at 180. | There's your clue.
At idle you probably have one of two issues.
1. Not enough air flow.
2. Not enough coolant flow.
There are two other problems that can cause overheating, but they should be evident at speed too.
1. Timing is retarded.
2. Fuel system is leaning out the engine.
06-19-2012, 12:13 AM
#29 | | Registered User
Ok so i instaled a nice electric fan set up today seem to b workn good but wasnt very hot today when i finaly finished. Gonna b a warm one tomorrow we see what happen i realy hope this helps. Fan is rated at 3300 cfm
07-11-2012, 06:56 PM
#30 | | Registered User
So its hot here again and now back to same old overheating probs. im at a complete loss. Everything on coolant system is new Even hit the smog shop and used there sniffer to check for blown headgasket. Car gets up to about 210 and then i shut it down. 😖
07-11-2012, 07:06 PM
#31 | | Senior Member
sid you check your timing?
does it only do it when sitting idling?
you can try flushing the radiator to.
07-11-2012, 07:10 PM
#32 | | Registered User
Wow you got a whole new cooling system, ever tried water wetter or related items? I wouldn't say it would fix what is wrong with your car but it could help you for the rest of the summer
__________________  having a fine car that is slow is like having a hot girlfriend that won't put out!
07-11-2012, 07:28 PM
#33 | | Registered User
Yes timing is right have flushed many times Can sit in driveway with cap of it will stay at 180 when i put cap on and drive it gets hot. Yes have tried water weter Have pressure checked system Found one small leak. But still same outcome always gets hot
07-11-2012, 07:54 PM
#35 | | Registered User
Thinkn maybe a highflow pump to. I put a new one but its from kragen Prob was bad idea shoulda went highflow from the gate
