Sleeper - Mustang Evolution
Old 06-16-2012, 01:41 PM   #1
Jimmygun911's Avatar
Sleeper
I have a 1986 with a 302. She has a tap happening but can't pinpoint it. Rods aren't bent and I put a new rocker arm on. Any input?
Jimmygun911 is offline   Reply With Quote
Old 06-16-2012, 01:45 PM   #2
Chris01's Avatar
Rocker adjusted properly?
Chris01 is offline   Reply With Quote
Old 06-16-2012, 01:48 PM   #3
I believe so. I turn the crank until the valves are down and tighten by torque specs.
Old 06-16-2012, 01:58 PM   #4
Chris01's Avatar
Ok does it tick faster when you rev the engine..Maybe exhaust leak
Old 06-16-2012, 02:00 PM   #5
I Rev the enging and it will go away for a couple seconds when I hit 2500-3000 rpms. The hits idle and starts again. I have new lifters coming, and thinking about getting heads cuz I was thinking a bent valve
Old 06-16-2012, 08:43 PM   #6
Chris01's Avatar
It's possible but can't say for sure. I don't want you to spend money that you don't need to because heads are not cheap.. I finnaly save some money and bought me the trickflow street kit which I have to say is very nice
Old 06-16-2012, 09:04 PM   #7
Vacuum Gage time
1fst86 is offline   Reply With Quote
Old 06-17-2012, 12:40 PM   #8
She's carburated
Old 06-17-2012, 07:39 PM   #9
This is one of my favorite tools in the box.
http://www.autozone.com/autozone/acc...scope/_/N-26gd
Old 06-18-2012, 09:48 AM   #10
garbill2003's Avatar
I agree every tool box should have one
garbill2003 is offline   Reply With Quote
Old 06-18-2012, 05:52 PM   #11
Hook a vac gauge to any intake vac port and run the engine the needle should stay around 12 inch or more and be still not jumpy this is an easy way to check basic health of your engine
1990mustang5.0 is offline   Reply With Quote
Old 06-19-2012, 01:52 AM   #12
Re: Sleeper
If you have a bent valve, then you may be beating the crap out of the top of your piston(s) and the valve seat and head.
If it goes away when you rev it a bit, then I would suspect that you have a lifter that is collapsing at lower oil pressure.
Since you are replacing them, you will be able to see if that was the problem.
You might want to try and get a look into the cylinders and see if you can see any dings in the tops of the pistons. If any local mechanics have a borescope, that would make doing that much easier.
02:43 PM
