Wiring diagram - Mustang Evolution
Old 06-18-2012, 12:19 PM   #1
Quball19's Avatar
Wiring diagram
Anyone have a wiring diagram for battery relocation? Does anyone know of inexpensive way to do without buying a 150 doller kit?...
Just asking .....
Quball19 is offline   Reply With Quote
Old 06-18-2012, 03:46 PM   #2
Quball19's Avatar
Got it never mind
Old 06-18-2012, 03:57 PM   #3
Quball19's Avatar
Originally Posted by Quball19
Got it never mind
I believe this will work
Old 06-18-2012, 07:55 PM   #4
oh damn. sorry man. i read this earlier but didnt have time to dig it up. glad you got it though.
Old 06-19-2012, 02:03 AM   #5
Re: Wiring diagram
Where did you find that?
I am curious as to why they used 2, 135 Amp circuit breakers and why they thought it necessary to run 2 power cables back up to the engine compartment.
I would add some braided ground cable and run that all the way back to the engine compartment too, so you can be sure to get adequate grounds to your engine and electronics. Just grounding to the car frame or body puts a lot of unreliable metal and resistance into your ground circuit and can cause problems.
I chose the braided ground cable because you can open the braid and secure it with a SS screws and washers to the frame and body along the way which increases the ground contact of them. I also recommend using a smaller piece of grounding braid and running it from the larger braid directly to your ECU to ensure it has adequate grounding.
Old 06-19-2012, 04:21 AM   #6
Quball19's Avatar
I ended up googled it, only diagram I found. Sorry can't remember where found.
---------- Post added at 04:21 AM ---------- Previous post was at 04:17 AM ----------
I will try to find again
Old 06-19-2012, 04:32 AM   #7
Re: Wiring diagram
If you can, I will check into why they did it that way, then I will redo the drawing to how I think it should be done.
Old 06-19-2012, 06:49 AM   #8
Quball19's Avatar
Ok didn't find original but looks like the one I posted. Sorry can't paste it, but its on (corral.net) they got different ways debating it, see what you think ........
Old 06-19-2012, 09:00 PM   #9
Re: Wiring diagram
I found it.
I'm going to work on a diagram of how I intend to do the swap on my 86 GT.
If you want you can wait to see it or go with whatever you think will work for you.
I have some differing ideas than what I have found and I want to work out a way to keep from spiking the electrical system if/when the system shutdown switch is activated for testing purposes.
Old 06-20-2012, 03:37 AM   #10
Quball19's Avatar
I found it.
Yes I can wait. Thank you.
Old 06-23-2012, 06:20 AM   #11
Re: Wiring diagram
Ok, after some research here is what I intend to do. Note, that I may change my drawing/wiring, if I run across any information that will improve or disprove what I have come up with so far. I will try and remember to post up any changes on this forum.
I plan to use 1/0 power cable (Red) and 1/0 flat braided ground cable. The wire to the alternator will be an 8 gauge wire.
Name:	Battery Relocation DWG.jpg
Old 06-23-2012, 06:31 AM   #12
Quball19's Avatar
Cool thanks...keep me informed on any changes
« 0-60 | Hp? »
03:38 PM
