camshaft - Mustang Evolution
Old 06-18-2012, 07:54 PM   #1
Jimmygun911's Avatar
camshaft
I took the lifters out. One lifter hole feels rough is their anyway to sand or clean it? I am trying to figure out if my cam is stock or not the numbers on it are F3H288U. I appreciate the help guys.
Jimmygun911 is offline   Reply With Quote
Old 06-18-2012, 08:02 PM   #2
General Kinetics
F3H-288-U
280°
280°
230°
230°
0.512''
0.512''
110°
2,000 – 6,000
its a lunati cam. http://paceperformance.com/i-5141977...l-kinetic.html
Old 06-18-2012, 08:45 PM   #3
What should I do about the one lifter hole feeling rough.
Old 06-18-2012, 08:56 PM   #4
as long as it isnt to bad you could sand it. i would try to be careful about getting to much junk in the motor. maybe plug some holes and cover with rags. i also would try to not take to much material off. just enough to smoot it.
Old 06-18-2012, 09:22 PM   #5
Alright. I have the same cam coming different duration thought. I believe it was 284
Old 06-19-2012, 02:10 AM   #6
Re: camshaft
If you have a lifter bore that is roughed up bad enough to require sanding or honing you really need to tear the engine completely down to do that. Any debris in that area will get into your oiling system and get carried to your bearings. Plus, if you remove too much material there it will leak oil badly around that lifter and it may not pump up enough to work properly.
04:46 PM
