bars welded under the car? - Mustang Evolution
Old 06-18-2012, 08:53 PM   #1
dray492's Avatar
Today my shifted got stuck in drive so I had to get under the car and pull the ?shifter? Into park and while I was under there I saw some long bars welded to the car and they had a sticker on them that's said something performance. What are these? Also anyone have any idea what would make my shifted get stuck like that? It's a bbk slap shifter.
dray492 is offline   Reply With Quote
Old 06-18-2012, 08:57 PM   #2
NeedSomeMods's Avatar
Subframe connectors. Google image search and see if that's what you got.
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 06-18-2012, 09:18 PM   #3
dray492's Avatar
That's it, thanks
---------- Post added at 10:18 PM ---------- Previous post was at 10:14 PM ----------
Anyone know why the shifter would stick like that? It wouldn't budge in the car but shifted easily when I had to do it under the car.
Old 06-18-2012, 09:24 PM   #4
93slowstang's Avatar
Originally Posted by dray492
That's it, thanks
Maybe the linkage got hung up?
Old 06-19-2012, 02:13 AM   #5
Re: bars welded under the car?
Cable shifter?
A burr on the cable or a kink might cause that, also if the cable housing ends are not fastened securely it causes shifting problems.
Old 06-20-2012, 08:52 AM   #6
dray492's Avatar
Originally Posted by Trojan Horse
Cable shifter?
I believe it is. So I went to get in my car this morning and it won't go into drive, it shifts from park to reverse to neutral and back fine but will not go into drive and if I get under the car and shift it into drive it won't go back into neutral. Im getting so frustrated. Help please!
Old 06-20-2012, 09:20 AM   #7
Sounds like the shifter in the console is on it's way out.
1fst86 is offline   Reply With Quote
Old 06-20-2012, 09:40 AM   #8
subframes are great, fox bodies REALLY really need them anyway
Old 06-20-2012, 07:28 PM   #9
It may just be out of adjustment too.
Research how to adjust it, then do so and see if that helps.
Old 06-20-2012, 09:32 PM   #10
dray492's Avatar
I will do that now, thank you
Old 06-20-2012, 10:14 PM   #11
You're welcome & good luck.
« Track | O2 sensors? »
10:53 PM
