Crankcase Evacuation Pump - Mustang Evolution
Old 06-19-2012, 03:23 AM   #1
Yesterday I spent a couple of hours at my cousin's shop helping him sort out the wiring on his latest racecar. (632 C.I. GM Beretta, Dyno tested at 1250 HP NA with 700 HP worth of nitrous to be added once it has been sorted out at the track, in case you were wondering. )
Anyways, for helping him sort out the wiring he gave me a new Ford Racing Crankcase Evacuation Pump to use on my engine when I install the Paxton Novi.
Have any of you installed one of these or something similar on a Fox Body 5.0?
If so, I'd be interested in reading about how you did it.
Old 06-20-2012, 12:32 AM   #2
Re: Crankcase Evacuation Pump
Anyone?
Old 06-20-2012, 06:45 AM   #3
Quball19's Avatar
Now im a backyard , forum asking fool here, but I found this if helps..
M-9486-A460 Crankcase Evacuation
I hope this comes threw......
Now I know nothing about this pump, just seeing what I find, if helps good, if not I tried..... Just saying.
---------- Post added at 06:45 AM ---------- Previous post was at 06:44 AM ----------
its didn't ill try again.... my bad
Quball19 is offline   Reply With Quote
Old 06-20-2012, 09:24 AM   #4
If I remember correctly, it runs off of the belt drive and it pulls vacuum from the valve covers to help control crankcase pressure, is that what ur asking??
1fst86 is offline   Reply With Quote
Old 06-20-2012, 10:32 AM   #5
What kind of ideas do you have already? Is it just like a smog pump? Or does it hookup like a pcv?
Old 06-20-2012, 12:20 PM   #6
Sport of like a smog, but the set ups I've seen usually have AN fittings on the valve covers and lines running to the pump. I don't believe u run a pcv. I've seem it on high horsepower motors where it actually helped male a few more horses with it bolted on.
---------- Post added at 12:20 PM ---------- Previous post was at 12:19 PM ----------
Originally Posted by 1fst86
Sort of like a smog, but the set ups I've seen usually have AN fittings on the valve covers and lines running to the pump. I don't believe u run a pcv. I've seem it on high horsepower motors where it actually helped male a few more horses with it bolted on.
Old 06-20-2012, 03:02 PM   #7
oh yeah. i was wondering! lol
Old 06-20-2012, 05:32 PM   #8
Thanks for your efforts, I found it on the Ford Racing site, but they don't give much info on installation.
On my car it will fit right where the smog pump is, because that is actually what it is. It has been modified to use the AN fittings which one connects to a valve cover and the other goes to an oil separator can with a vent.
Yes, it is just a smog pump that has been modified to work as a vacuum pump.
I know that for race cars they seal up everything pertaining to the crankcase as tightly as they can. I'm thinking that for a street driven car you might not want to seal it up quite as tightly and provide for a bit of air flow to keep from burning the pump up because you will be running the engine much longer than just down the 1320.
So what did you guys think about the car he's building? (He built the engine himself too.)
I was going to get some pics, but I forgot my cell phone.
My jaw hit the floor when he told me he was adding 700 HP with the nitrous.
He is expecting to run 3.80's in the 1/8th mile.
Old 06-20-2012, 05:36 PM   #9
i think that thing sounds insanley fast. under 4 in the 1/8 is ridiculous. would be probably faster than a prostock car. my local track has door slammer cars doing high 4s and they are fun to watch.
im guess that nitrous is multiple stages? maybe 300, 200, 200,? sound like hes gonna have to change the bottle every pass! lol
Old 06-20-2012, 06:46 PM   #10
Two stage system 400 in the first stage, then 300 in the second stage.
I'd be happy with the engine power alone. 1250 HP and 962 ft lbs of TQ.
That's not guessing either, he showed me the Dyno sheet.
Old 06-21-2012, 06:14 AM   #11
Daaammmnn. Boy I would kill to be able to hit that go button one time. :drool:
05:09 PM
