X3z vs a9l - Mustang Evolution
Old 06-19-2012, 12:25 PM   #1
Finchms's Avatar
X3z vs a9l
My buddy is converting his car to mass air and I've been helping him look for a computer. I came across a x3z from a cobra. I know its calibrated for 24lb injectors, which he will be running. He also has a bbk 76mm mass air calibrated for #24s. Should it be ok to run this or should wait on an a9l? What other difference is there between them?
Finchms is offline   Reply With Quote
Old 06-20-2012, 12:55 AM   #2
Re: X3z vs a9l
It will work fine and since it is already calibrated for the 24 lb injectors he won't really need the MAF calibration too. A stock Cobra MAF would probably work better since it will not need to correct the injector calibration within the ECU.
Old 06-20-2012, 06:09 AM   #3
Finchms's Avatar
The maf came from bbk and is already calibrated for 24lb injectors. Will this still work fine with no problems? Thanks for the reply
Old 06-20-2012, 09:51 AM   #4
Re: X3z vs a9l
I'm not sure. It may interfere with the computer programming.The best thing to do is to contact BBK and ask them.
Old 06-20-2012, 10:01 AM   #5
Finchms's Avatar
Ok. Thanks alot
Old 06-20-2012, 08:29 PM   #6
Re: X3z vs a9l
Ok. Thanks alot
You're welcome and good luck with his project.
10:59 AM
