Track - Mustang Evolution
Old 06-19-2012, 04:04 PM   #1
FoxBody9315's Avatar
Track
On my way to race my pony wish me luck lol :p
FoxBody9315 is offline   Reply With Quote
Old 06-19-2012, 04:07 PM   #2
Good luck. We expect mod lists and time slips.
Old 06-19-2012, 06:18 PM   #3
Embarrassing straight embarrassing
Flow masters headers cai short shifter
I ran. 16.4 reaction time .5 top speed 90
Old 06-19-2012, 06:37 PM   #4
Chris01's Avatar
Is that all the upgrades? Some gears might help also
Chris01 is offline   Reply With Quote
Old 06-19-2012, 07:10 PM   #5
You don't have a whole lot of mods. A stocker will fun around 15 flat. Could be inexperience, track,conditions
---------- Post added at 08:10 PM ---------- Previous post was at 08:08 PM ----------
What was your 60 ft time?
Old 06-19-2012, 08:39 PM   #6
captain78's Avatar
All stock with gears I ran 14.9 and 14 flat with slicks
captain78 is offline   Reply With Quote
Old 06-19-2012, 08:41 PM   #7
Jimmygun911's Avatar
What year are you running to hit 14 flat. Is that a automatic or stick?
Jimmygun911 is offline   Reply With Quote
Old 06-19-2012, 09:05 PM   #8
Gears I have 4:10 my 60ft was 2.7
Old 06-19-2012, 09:06 PM   #9
captain78's Avatar
90 GT 5 speed. 3:73 gears
Old 06-19-2012, 09:06 PM   #10
Something got to be up with my car I'm obviously on the right
Old 06-19-2012, 09:07 PM   #11
Eek. You have major traction issues my friend. I bet with just some.good tires you knock 1 1/2 seconds off, easy.
Old 06-19-2012, 09:12 PM   #12
captain78's Avatar
I had a 1.95 60ft without slicks and 1.80 with slicks
---------- Post added at 10:09 PM ---------- Previous post was at 10:08 PM ----------
Coulda been in 13s but I have bad syncros in my tranny
---------- Post added at 10:12 PM ---------- Previous post was at 10:09 PM ----------
What rpm r u leaving line at
Old 06-19-2012, 09:13 PM   #13
4
Old 06-19-2012, 09:14 PM   #14
captain78's Avatar
Street tires
Old 06-19-2012, 09:14 PM   #15
Street tires
im betting
Old 06-19-2012, 09:15 PM   #16
Street tires
Prett much yeah the guy I bought ye car off of had just put brand new tires on it
Old 06-19-2012, 09:18 PM   #17
captain78's Avatar
There's your problem I bet your also spinning 1st and 2 nd bad next time leave line like a red light leave at idol
---------- Post added at 10:16 PM ---------- Previous post was at 10:16 PM ----------
And ease into gas
---------- Post added at 10:18 PM ---------- Previous post was at 10:16 PM ----------
My first few passes was the same thing but they had guys there to give me tips each pass
Old 06-19-2012, 09:20 PM   #18
And ease into gas
Yeah I spinner 1st but not second
Old 06-19-2012, 09:23 PM   #19
captain78's Avatar
There's also something's you can do to help also like remove your air box. Advance your timing a tad. And unplug your water temp sensor. And try a couple passes without doin a burn out and don't go through water trap
---------- Post added at 10:23 PM ---------- Previous post was at 10:23 PM ----------
Some say you can even remove your belt
Old 06-19-2012, 09:25 PM   #20
Air box ? And timing I did over the weekend lol I guess I'll be spending another day at the track
Old 06-19-2012, 09:27 PM   #21
i wouldnt suggest removimg the belt. i suppose it will free up a little power but not worth not pumping water and charging imo. serious guys run nothing and charge there battery in between every pass.
also im curious of removing the water temp sensor?
Old 06-19-2012, 09:28 PM   #22
captain78's Avatar
Behind air box there's a funnel type thing pull it out and when you run pull the air box cover and filter it will help with airflow
Old 06-19-2012, 09:29 PM   #23
Are you talking about the intake bc I have a bbk intake into the fender with no filter
Old 06-19-2012, 09:31 PM   #24
captain78's Avatar
Just unplug it it's the plug on left hand side of motor it tricks the computer into thinking its in circulation and is cooler than it is I picked up a half a second just by unplugging it just need to allow longer period inbetween runs and remember to plug it back in.
Old 06-19-2012, 09:32 PM   #25
The mass air sensor ? Ok so I do that lol I'm down to 16 flat theoretically
Old 06-19-2012, 09:32 PM   #26
oh ok. im not sure thats the safest trick, but a 1/2 second is impressive!
Old 06-19-2012, 09:34 PM   #27
+1
Old 06-19-2012, 09:36 PM   #28
keep in mind there are alot of variables. different tracks, climates, etc. once you get more passes under your belt, you will figure out some of the things cap said. your launch is key. the 60ft is the most important. a perfect launch is when you may hey a tiny bark/schreech, but only for a split second. that is basically the hardest you can launch with out breaking loose
Old 06-19-2012, 09:36 PM   #29
captain78's Avatar
Nooooo not mass air sensor the water temp sensor it's on the intake
Old 06-19-2012, 09:37 PM   #30
yeah what he said^
you will probably lose time unplugging the maf. and risk running an improper fuel mixture.
Old 06-19-2012, 09:38 PM   #31
Gotcha
---------- Post added at 09:38 PM ---------- Previous post was at 09:37 PM ----------
Gotcha sir I will def try that next time
Old 06-19-2012, 09:41 PM   #32
captain78's Avatar
It's on left front side of intake
Old 06-19-2012, 09:46 PM   #33
Props on the pic thank you man will def do that next time
---------- Post added at 09:46 PM ---------- Previous post was at 09:45 PM ----------
I just got my h pipes in today like an hour before I went to the track so they will be on next time I go
Old 06-19-2012, 09:47 PM   #34
captain78's Avatar
Just unplug and turn your key on and off a few before starting
Old 06-19-2012, 09:48 PM   #35
captain78's Avatar
This is what mine looks like at the moment
11:35 AM
