Off road h pipe - Mustang Evolution
Old 06-20-2012, 07:50 PM   #1
Foxcrazy's Avatar
Off road h pipe
M putting a 3" offload h pipe on my 91 foxbody... What do I do to the random hose that can no longer has a place to go. I'm guessing this is a evap hose or something to do with emissions.... Can I just plug the damn thing or do I need to leave it open?
Foxcrazy is offline   Reply With Quote
Old 06-20-2012, 09:52 PM   #2
Re: Off road h pipe
Are you talking about your smog pump injector hose?
If so just let it vent to the atmosphere somewhere unobtrusive or remove it and the pump.
Old 06-20-2012, 10:07 PM   #3
Foxcrazy's Avatar
Im guessing that's what it is... It's the metal line that runs back toward the motor... It was what hooked H pipe and had a smaller piece of pipe that connected the two lager pipes before the second set of converters and the h part of the pipe. I left it open and the car is running fine.
Old 06-20-2012, 10:26 PM   #4
Re: Off road h pipe
Yes, that is the smog pump line.
It connected to the lower check valve in the diagram below.
Old 06-20-2012, 10:39 PM   #5
Foxcrazy's Avatar
You always have the right info... Thanks again, and I'm guessing that someone forgot to take that part off because I know that there isn't a pump on my motor... All I got is a water pump, power steering, AC, and alternator. And I'm pretty sure I didn't see any of the other lines running around the motor like that. Guess I'll take care of the rest tomorrow.
Old 06-20-2012, 11:25 PM   #6
Re: Off road h pipe
Glad I was able to help you.
Old 06-21-2012, 06:25 AM   #7
The part that bolts in the back of the heads can be plugged with a 5/8 11 bolt. Use a short one with thread sealant.
03:30 PM
