timing????? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-21-2012, 10:22 PM   #1
fordracing63857 is unknown around these parts
timing?????
Was wonder how much I could advance or retard the timing on my car to get a few xtra horsepower?!?!?
fordracing63857 is offline
Old 06-21-2012, 10:41 PM   #2
Moderator
93slowstang's Avatar
93slowstang is unknown around these parts
About 14* advanced base timing seems about the sweet spot. You may need to use premium grade fuel to prevent detonation.
93slowstang is offline
Old 06-22-2012, 01:29 AM   #3
bad_little_pwny's Avatar
bad_little_pwny is unknown around these parts
Anyone in a 5.0 should be running premium anyway...I know you know that just saying as a general statement
bad_little_pwny is offline
Old 06-22-2012, 03:33 PM   #4
Senior Member
dreamstang is unknown around these parts
I disagree. If you run stock timing NA then you are simply wasting money imo
dreamstang is offline
Old 06-22-2012, 08:12 PM   #5
Filibuster
XXSTEVEO66 is unknown around these parts
+5.0 I'd run 87 in mine if I didn't have the timing advanced 14° but imo it woke the stang up enough to keep it that way!...and only run 93 to keep away from detonation.
XXSTEVEO66 is offline
Old 06-22-2012, 08:22 PM   #6
Senior Member
right on. i run 15-16 * base timing with 36* total timing. so i am not risking it!
Old 06-22-2012, 08:35 PM   #7
So should I set my timing at 14* or 36*?!? I'm confused here.....
Old 06-22-2012, 08:40 PM   #8
Senior Member
14* is what you should set it at with premium fuel. this is at idle
the 36* is at wot with my mechanical advance mechanism.
the reason i run a little higher timing than everyone is because i can get away with a little more with the aluminum heads. i have actually read of people with my heads saying 17* base timing is the sweet spot. but i am a sissy. maybe when i go to the track after a few passes i may try it, after i make sure its not detonating.
Old 06-22-2012, 08:43 PM   #9
Senior Member
Trojan Horse is just getting started.
Re: timing?????
Set your base timing to 14°. The 36° is the total timing and he is carbureted, not using the EFI computer, so he needs to control his timing advance all the way through himself.
P.S. I run 87 octane in my 86 GT all the time with the timing set to factory specs and no issues. Unless your engine has 10.5 compression or higher there is no need for premium fuel unless you just want to pay the extra for it.
Trojan Horse is offline
Old 06-22-2012, 08:48 PM   #10
Senior Member
yeah i guess i should hve been more specific.
so you dont advance your timing? im curious
Old 06-22-2012, 09:23 PM   #11
Senior Member
Re: timing?????
No, you did fine. I was writing that at the same time as you were writing your answer and you just beat me to the post.
Only when the situation calls for it and I have good fuel in the car.
With the power it makes I'm pretty happy with how it runs on 87 octane fuel.
I can be rolling at 15-20 mph in second and ease into the throttle and break the back tires loose as it was, so more is less sometimes. Hopefully the suspension and tire change will help the hook.
I really want to get the SC on it and see if I can do that in 4th at highway speeds.
Old 06-22-2012, 09:32 PM   #12
Senior Member
ok, gotcha.
i can break them loose at over 30-35. but i gotta drop it pretty hard. and it will just break loose. i am actually real happy with my suspension. it actually hooks better now, then before i upgraded my motor. that is unless i drop it hard. i think my real low ride height helps the lift bars out.
i bet you will have no problem breaking the tires loose at many speeds when all said and done. :drool:
Old 06-22-2012, 09:37 PM   #13
Senior Member
Re: timing?????
ok, gotcha.
My "extensive" lightening of the car has had some adverse effects. I'm hoping that relocating the battery to the back will help traction issues a lot. Replacing the factory hatch and glass with a fiberglass hatch and Lexan and removal of the rear seats, removed a lot of weight off the rearend, so I may end up having to add some weight back there.
Old 06-23-2012, 09:55 AM   #14
Filibuster
Ha!...so you know the bad side of lightweight fox's!...absolutely NO traction!.my stang sounds and feels fast,but NOPE!...1st gear is a joke just spinning...and with that said these lightweights are capable of 12sec quarters on motor and suspension alone!..
---------- Post added at 10:55 AM ---------- Previous post was at 10:53 AM ----------
And gears
Old 06-23-2012, 12:02 PM   #15
Senior Member
Re: timing?????
And gears
Yes indeed I do.
Even my daughter's stock 89' Convertible can get pretty squirrely if you are not careful.
I'm hoping and thinking that removing the springs from the lift bars and using coil overs will help a good bit.
Old 06-23-2012, 02:48 PM   #16
Haav's Avatar
Haav is unknown around these parts
Hey what timing shoud I use for 93 octane gas?
Haav is offline
Old 06-23-2012, 02:54 PM   #17
Senior Member
If you have stock timing then just run 87.
Old 06-23-2012, 08:04 PM   #18
Haav's Avatar
Well, I'm sure it's slightly advanced because when I bought it the guy said he slightly advanced it and I've never touched it. I hear detonation at low rpms though.
Haav is offline
Old 06-23-2012, 08:33 PM   #19
Senior Member
93 should fix it.
I would invest in a timing light.
Old 06-23-2012, 09:49 PM   #20
Haav's Avatar
93 should fix it.
Yeah ima get me a timing light. I been using 93 all month because I used to use 87 octane ( the cheapest) and I heard detonation rattle sounds and that's why I went to 93. So I changed fuels now I gotta mess with the timing I guess.
Haav is offline
Old 06-23-2012, 10:06 PM   #21
Senior Member
Check your timing. You may want to just run the 93 if your timing is in the 12-14 range. If it is and you go back to stock you may be disappointed.
Old 06-23-2012, 10:11 PM   #22
Haav's Avatar
Ok so 12 to 14. I'll keep that in mind. I can't wait to finnally get this car to drive like it used to. It feels like its not using its full power because of detonation. Thanks.
Haav is offline
Old 06-23-2012, 10:16 PM   #23
Senior Member
Stock timing is 10. People usually advance in the 12-14 range, but usually run premium. Every car is different. If you want to run 87 and still try to advance it a bit. You can start at 10. Then bump it up a little at a time. Whenever you hear detonation then back it off 2.
To check for detonation. I usually put it in 4th gear at about 20 mph so it loads the engine.
Old 06-23-2012, 11:35 PM   #24
deadsp0t's Avatar
deadsp0t is unknown around these parts
I've read that some engines with stock pistons and heads like it as high as 15*-16*. 14* seems to be the standard though.
My first 95 liked 15*, my thought was is was a combo of weather and the diet my car was on. It was a GTS to start with and I striped everything I could out minus seats and carpet lol
That's unimpressive
deadsp0t is offline
Old 06-23-2012, 11:39 PM   #25
Filibuster
I still think mine could go more then 14° but but im stayin there just to be ”safe”..
Old 06-24-2012, 02:35 AM   #26
Senior Member
My timing is right between 15-16. But I have the advantage of aluminum heads.
Old 06-25-2012, 06:02 AM   #27
Fox 5.0's Avatar
Fox 5.0 is unknown around these parts
I read in a thread awhile back that 32 degrees is the way to get maximum throttle response. Idk what mine is set on I've just loosened the bolt and turned the distributor till its at max response.I know stock is 10 and I don't even know of you can even get it to 32. 0.0
Fox 5.0 is offline
Old 06-25-2012, 06:22 AM   #28
Senior Member
Re: timing?????
32° would be the total advance. You do not want to set the base timing that far advanced.
Your engine would detonate and beat itself to death in a very short time firing that far ahead of TDC if it would even start.
Throttle response is going to be different for each engine. It wouldn't matter if you built two engines exactly the same. Minor flaws and discrepancies in the engines would make them different.
If you are past 14° to 16° advance I'd bet your engine is detonating as it is.
Old 06-25-2012, 03:47 PM   #29
Fox 5.0's Avatar
How do you check your detonation??? I would like to find out because like I said I have no idea the degree its at. I know I could get a timing gun but if there's another way I would like to know??
Fox 5.0 is offline
Old 06-25-2012, 04:00 PM   #30
Senior Member
you need to load the engine, and carefully listen. people like to describe detonation as marbles bouncing around. or a rattling pinging type noise.
what you can do to load the engine is put it in a high gear like 4th. then go really slow, like 20 miles an hour. this should be able to load the engine eough. as you do this listen to the motor.
Old 06-25-2012, 07:23 PM   #31
Senior Member
Re: timing?????
Exactly like he said. ^^^
Choose a gear that is actually to high for the speed you are traveling and push down on the gas pedal lugging the engine down. If you hear a pinging, rattling or knocking sound that is the engine killer, detonation.
Old 06-30-2012, 12:21 AM   #32
Haav's Avatar
I filled the tank with 87, brought back timing and I lost all detonation(awesome!) but it felt like I lost power. So I advanced it a bit and got more power and it detonated only slightly, very hard to notice. Maybe I mess with it some more when I'm off of work again. My damn heater core pipe that floats over the intake manifold under the plenum sprung a leak. So I gotta fix that next. I'm thinking of reinforcing my engine you know? Like make it tougher for future mods. Where should I start with that?
Haav is offline
Old 06-30-2012, 12:40 AM   #33
Senior Member
Re: timing?????
DO NOT let it detonate very long or you will be taking the chance of serious engine damage.
You will lose some power as you decrease the timing, but that is necessary to keep it from detonating.
Look in the Superchargers and Turbos sticky thread for engine building tips.
Closed Thread
12:26 AM
