keeps cranking. - Mustang Evolution
Old 06-23-2012, 09:53 AM   #1
Jimmygun911's Avatar
keeps cranking.
So I have the car together now. New starter and selinoid, after trying to start her, she wants to keep cranking even after the ignition is off. I can't figure out the problem. I re-did most of the grounds. From the battery's to the block and from the block to the firewall.
Jimmygun911 is offline   Reply With Quote
Old 06-23-2012, 12:29 PM   #2
Re: keeps cranking.
The solenoid is bad (contacts welded together) or it's wired wrong.
Old 06-23-2012, 01:14 PM   #3
The selinoid could be wired wrong? I think everything's is good but there is one wire running from the seliniid through the firewall. I'm guessing the ignition. Could that cause a problem like this. I know fords always have ignition issues.
Old 06-23-2012, 05:22 PM   #4
Solenoid issue, check Ur wiring or grab another solenoid
1fst86 is offline   Reply With Quote
Old 06-23-2012, 06:13 PM   #5
I just got a new selinoid. I have a wire from the starter to the selinoid, a wire coming from my ignition I think to the selinoid and my positive wire going to the selinoid.
Old 06-23-2012, 10:35 PM   #6
Re: keeps cranking.
Post a picture of your solenoid and I will show you how it should be wired.
Old 06-24-2012, 11:10 AM   #7
OK....give me a couple hours
Old 06-24-2012, 03:16 PM   #8
Pics are up on a new thread
Old 06-24-2012, 03:42 PM   #9
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Why didn't you just post them on this thread?...
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 06-24-2012, 03:57 PM   #10
Old 06-24-2012, 05:37 PM   #11
1985MustangH3LL's Avatar
Looks like u have ur started single wire on the wrong Side of ur cylanoid
1985MustangH3LL is offline   Reply With Quote
Old 06-24-2012, 05:42 PM   #12
Coming from my starter to my seliniod? It should be on the other side. So the ground should be on that side?
Old 06-24-2012, 05:47 PM   #13
Re: keeps cranking.
Here is how to properly wire the solenoid.
You DO NOT connect a ground to any of the terminals.
Name:	Ford 4-Terminal Solenoid Wiring.jpg
Old 06-24-2012, 05:49 PM   #14
Nice man. Thank you.
Old 06-24-2012, 06:10 PM   #15
Re: keeps cranking.
You're welcome, good luck with your project.
04:54 AM
