Head work - Mustang Evolution
Old 06-23-2012, 01:38 PM   #1
Thrasher13's Avatar
Head work
Lookin at getting some head work done. Like porting polishing and shaving. I have factory e7 heads. I want gt40p cuz I know there better. I'm on a budget tho and I want to get this all done as soon as possible. I'm just wondering how much better the gt40s are. If I had worked e7s?
Thrasher13 is offline   Reply With Quote
Old 06-23-2012, 02:14 PM   #2
The e7s will barely, if any outflow gt40s after worked.
If your looking for good hp then find some good aluminum heads. If your strickly budget a gt40 swap maybe cheaper than working the e7s.
Old 06-23-2012, 03:06 PM   #3
Thrasher13's Avatar
Well I know a junk yard I can get heads off a 97 explore for 50
Old 06-23-2012, 03:10 PM   #4
Over stock the gt40s can see about 20-40hp with supporting mods.
A good set of aluminums can see up to 100+ hp with supporting mods.
Old 06-23-2012, 04:23 PM   #5
WhiteCobra94's Avatar
+1 with my HCI swap I gained 126 rwhp!
Old 06-23-2012, 05:26 PM   #6
Thrasher13's Avatar
How much could I get a good set of aluminum heads for?
Old 06-23-2012, 05:30 PM   #7
8-1200$
But if you can't fork that keep watching eBay, craigslist etc. But buyer beware. I've seen some people score some good deal.
Old 06-23-2012, 05:53 PM   #8
Thrasher13's Avatar
What are some good aluminum heads?
Old 06-23-2012, 08:32 PM   #9
Eldelbrock,afr,trickflow are a few of my fave
Old 06-23-2012, 09:33 PM   #10
Thrasher13's Avatar
Alright thanks man
Old 06-23-2012, 09:36 PM   #11
No problem.
Btw, when I installed my trickflow heads. It made my car feel like it wasn't even the same vehicle. :drool:
Old 06-23-2012, 09:43 PM   #12
93_347foxbody's Avatar
Re: Head work
how much of a difference would afr 185ccs make over gt40s?
93_347foxbody is offline   Reply With Quote
Old 06-23-2012, 09:45 PM   #13
A whole lot. Those heads are Awsome. You would probably be pretty impressed.
The only problem is the may require knotching the pistons.
Old 06-23-2012, 09:46 PM   #14
Re: Head work
just wondering whatd be the reason for notching them? and are notched pistons pricey?
Old 06-23-2012, 09:47 PM   #15
The afr 165s don't require knotching the pistons. and you would still see great gains. But if your motor is stroked you probably want heads comparable to the 185s.
Old 06-23-2012, 09:50 PM   #16
Re: Head work
yeah i was reading about 347stroker motors and everyone says gt40 heads arent a good choice so im putting money aside for afr 185s what else heads are close to as good as afr 185s but maybe not as pricey
Old 06-23-2012, 10:04 PM   #17
Trickflow heads usually have more clearance. I would look into the 185 or 205 from either brand. And also its hard to say what clearances you will have. It would help to know what pistons you have. But when doing a head swap, you can't ever be sure what piston to valve clearance you gonna have to you check.
Old 06-24-2012, 09:20 AM   #18
captain78's Avatar
I have the Afr 165s no Clarence issues at all. And they say there good for 100 hspr over stock
---------- Post added at 10:20 AM ---------- Previous post was at 10:20 AM ----------
And I'll prolly be using the same heads when I build my 331 stroker
captain78 is offline   Reply With Quote
05:58 PM
