Cam - Mustang Evolution
Old 06-23-2012, 03:01 PM   #1
Cam
Hey guys. I just got a comp cams cam with a duration of 286-296 and the lifters to go with it for $260.
Napoleon is offline   Reply With Quote
Old 06-23-2012, 03:03 PM   #2
You mean lift of 286-296?
Old 06-23-2012, 03:08 PM   #3
Ya I think so. It's hard to make out the guys handwriting. Lol
Old 06-23-2012, 03:14 PM   #4
Lift makes more sense. It would be a real mild cam. I would run 1.7 or even 1.72 rr with them.
Old 06-23-2012, 03:19 PM   #5
He said it was a very aggressive cam( not that I believe him 100%) I'm trying to look it up but I can't find it anywhere.
Old 06-23-2012, 03:39 PM   #6
it might be aggressive. its hard saying without knowing what it is for sure. the 286 can still be duration. and if so would be really aggressive.
i once saw a chart online that listed all cam manufacturese cams. with all the specs for them. i kick myself in the butt for not book marking it. but thats what you gonna have to do. is look at comp cams and check there duration and lift on there cams and see if you can find a match.
Old 06-23-2012, 03:45 PM   #7
I actually just found a site with something like that and found the cam. 232/240 duration @.50 and .565/.574 lift. 112 lobe separation. And here's that site. http://southeasternfoxbodies.com/for...ad.php?t=29205.
How aggressive is the cam?
Old 06-23-2012, 03:48 PM   #8
93slowstang's Avatar
Well this is what I found as far as searching for that duration. If this is what you bought it is a very radical cam. Idk if I would even try to use it.
Old 06-23-2012, 03:51 PM   #9
That's definitly the cam? Cause it doesn't say 286-296
But yes that is real agressive! You will probably have piston to valve clearance. I'm guessing you will have to knotch your pistons for it to clear. But I can't be sure.
---------- Post added at 04:51 PM ---------- Previous post was at 04:48 PM ----------
Yeah. That looks more right!
You would need serious heads, intake , probably stroked motor, knotched pistons. Whole nine yards.
Old 06-23-2012, 04:17 PM   #10
Sorry I forgot to mention I matched it to the number stamped on the cam. As far as pistons, I'm going to be buying a Stroker kit soon. Any suggestions for pistons?
---------- Post added at 05:17 PM ---------- Previous post was at 04:51 PM ----------
Thanks for all the help
« Timing ... | Oil »
08:08 PM
