Brakes! - Mustang Evolution
Old 06-23-2012, 06:26 PM   #1
Brakes!
I thinks its time to.upgrade to stanless steel lines..today I ran the car 3 times and after that brakes heated up and barly stopped =0 (kinda scary) rubber brake hose ant to good when hot lol
fast 94 5.0 is offline   Reply With Quote
Old 06-23-2012, 06:39 PM   #2
TtownMach1's Avatar
Subbed, been thinking of getting some myself. Wanna see how it turns out!
5-Speed-IUP, Predator tuned, k&n cai,Mrt shifter,Hooker Lts-o/f x-pipe, KC clutch,Alum flywheel,FR 4:10's. Upr rear control arms. Forged Teksid Eaton swap in progress!
WickedStangs Mustang Club
Tulsa,OK Chapter President
TtownMach1 is offline   Reply With Quote
Old 06-23-2012, 06:57 PM   #3
I put them on the cobra and noticed no more mushy pedal after autox or hard driving.
Also don't forget brake fluid needs flushing regularly as well. The type of fluid is also important.
Old 06-23-2012, 07:24 PM   #4
I was told like $200 for a set of.lines? Any truth to that
Old 06-23-2012, 08:46 PM   #5
Couldn't tell ya... Just see what the prices are
Old 06-23-2012, 09:11 PM   #6
Well how mich did u pay?
Old 06-23-2012, 10:48 PM   #7
Re: Brakes!
Brake lines alone are not going to cure your problem. About all they will really do is to firm up your pedal feel.You will need to upgrade the rotors, calipers and pads to alleviate the issue you mentioned.
Old 06-24-2012, 01:29 PM   #8
I paid 89$ for mine, but they won't cure brake fade. They'll just firm up pedal feel.
1fst86 is offline   Reply With Quote
Old 06-24-2012, 01:59 PM   #9
Hell if I know. Did it 3 years ago
Old 06-24-2012, 05:41 PM   #10
Well when u push the,brake to the floor n u barly stop,,scary lol
Old 06-24-2012, 08:14 PM   #11
Sounds like you need to invest in some new brake components
Old 06-24-2012, 08:16 PM   #12
Its only wen I run car n get brakes hot
Old 06-24-2012, 08:22 PM   #13
McNassty's Avatar
Sounds like your pads are glazing, I would upgrade to ceramic
McNassty is offline   Reply With Quote
Old 06-24-2012, 08:45 PM   #14
Have thoes already..
Old 06-24-2012, 08:47 PM   #15
Drilled slotted type rotors would help cooling a lot.
Old 06-24-2012, 08:58 PM   #16
Dont have thoes lol..iv seen brembo front brake setup with drilled/slotted rotors for $1200..might get it..then later invest in back brembos
Old 06-24-2012, 10:22 PM   #17
McNassty's Avatar
The drilled and slotted rotors help prevent glazing by keeping your brakes cooler. I have the BAER ones and I love em
Old 06-25-2012, 08:10 AM   #18
They're also prone to cracking and breaking under heat.
Best rotors out there are vented blank rotors.
Old 06-25-2012, 09:48 AM   #19
McNassty's Avatar
That's only if they aren't dimpled on the holes and slots. Mine are dimpled and I haven't had any trouble with them and trust me I have put them under stress
Old 06-25-2012, 12:18 PM   #20
wheelman's Avatar
Also upgrade to DOT4 if you havent already. I boiled my fluid and lost brakes for about 15-20 seconds...effing scary. DOT4 wont boil.
wheelman is offline   Reply With Quote
Old 06-25-2012, 03:30 PM   #21
Geez man I woulda ***** a brick lol..wen my pedal mushed out big time I was like wtf!!
Old 06-25-2012, 06:56 PM   #22
Re: Brakes!
Some detail on drilled/slotted rotors and what works/breaks and what doesn't would be great if you guys have anymore knowledge to share.
I've never heard of vented blank rotors, is that something new or are you talking about the factory style rotors with the angled cooling vents in the center?
Old 06-25-2012, 07:03 PM   #23
Re: Brakes!
+1000
Years ago I built a 429/C6, F150 pickup and stupidly neglected to upgrade the drum brakes.
One episode of that and I was out securing disk brakes for a conversion.
Fear and butt clinchery happens and escalates exponentially when you are pushing on the brake pedal as hard as you can and the vehicles is not stopping or at least slowing down appreciably.
Old 06-25-2012, 09:04 PM   #24
I agree. I haven't noticed any cracks appearing in mine. Dimpled/slotted/vented. Hawk hps+ pads.
Just wanted to warn anyone who's going to treat them hard.
---------- Post added at 10:04 PM ---------- Previous post was at 10:03 PM ----------
They are what come factory on the cobra. Hard core track guys swear by a blank rotor.
Old 06-25-2012, 09:07 PM   #25
McNassty's Avatar
When you buy drilled and slotted rotors if they are not dimpled at the edges than cracking occurs. Dimpling is when they drill the holes and than come in with a larger size bit just a little bit and round out the entry ports to the drill holes and slots. It rounds the entry on the holes so that when the brake pads compress against the rotor it stops outward pressure on the holes and slot thereby reducing stress cracks
Old 06-25-2012, 09:40 PM   #26
Re: Brakes!
Ahh Ok, Thanks.
+1
That's called chamfering and it's a standard machining practice.
Old 06-25-2012, 10:39 PM   #27
McNassty's Avatar
Ahh Ok, Thanks.
+1
Yeah but they call it dimpling
---------- Post added at 04:39 AM ---------- Previous post was at 04:37 AM ----------
They just wouldn't feel right unless they make it sound like they created that lol
Old 06-26-2012, 12:00 AM   #28
Re: Brakes!
Ok, if that's what they want to call it I suppose it's their choice.
Maybe someone should tell them that dimples belong on cute little girls, not brake rotors.
Old 06-26-2012, 06:49 AM   #29
McNassty's Avatar
+1 LMAO!!!
Old 06-28-2012, 05:15 PM   #30
Getting my brakes done this week,,getting stanless steal lines, flushing the system,putting better brake fluid..$300 for the whole job..not to bad
Old 06-28-2012, 10:07 PM   #31
Blogger
99ford's Avatar
That's cheap !
Old 06-29-2012, 05:22 PM   #32
New lines and brake fluid for 300$?
Old 06-29-2012, 05:40 PM   #33
Yea stanless steal lines..new/better fluid n labor..$300+tax idk what yhe total is after tax
Old 06-29-2012, 07:25 PM   #34
Seems a bit high are they doing from the front to the back or just the hoses
tbonestang is offline   Reply With Quote
Old 06-29-2012, 10:40 PM   #35
Front n back
09:15 AM
