Acceleration lag.. - Mustang Evolution
Old 06-24-2012, 07:12 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Acceleration lag..
It seams like I press on the gass and it takes a second to get up and go.. Any ideas like
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-24-2012, 07:29 PM   #2
Need more hp! Lol
Could be lots of things. I would do a basic tune up. Clean maf and iac. Check plugs and wires. Change fuel filter. And run some injector cleaner through her.
Old 06-24-2012, 07:52 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
Originally Posted by dreamstang
Need more hp! Lol
Plugs and wires are don't fuel filter is on the way.. And yes I do need more maf is clean.
2001 GT - True Blue
Old 06-25-2012, 07:36 AM   #4
slow281
sixpac's Avatar
Region: Nebraska
Need more hp! Lol
But it's not so much like in the running part..? It's like it almost stalls for a second before it starts to go.. Like this.. Hit the gas... Wait half a second... Then throttle opens..
2001 GT - True Blue
Old 06-25-2012, 01:18 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
Fixed my own problem bought a 9$ resonator of eBay and plugged it into the AIr temp Sensor and runs like a champ..
2001 GT - True Blue
Old 06-25-2012, 02:08 PM   #6
Iluvmy5.0's Avatar
Hold on, what happened? 9 dollar resonator? Or resistor?
Iluvmy5.0 is offline   Reply With Quote
Old 06-25-2012, 02:11 PM   #7
That's a band-aid
1fst86 is offline   Reply With Quote
Old 06-25-2012, 02:12 PM   #8
Iluvmy5.0's Avatar
Oh, and what did you search on eBay? Just curious cause my buddy has an '86 and complains about the same problem. We gave his a basic tune up. Checked timing, plugs, wires, maf, iac, all sensors. No check engine lights. Fuel filter ran injector cleaner. It's crazy cause you can pin the gas and it does zero for a second and then it explodes with all of its power and full exhaust note and two black strips of rubber. It feels like a drive-by-wire car.
Old 06-25-2012, 02:58 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
I'll take pictures tonight I searched 2001 v6 mustang chip.. And it says like 50+ hp 20+ mpg even tho that's a bunch of BS I used it for my 93 it for anything it was like 9.50 or 10$
2001 GT - True Blue
Old 06-25-2012, 08:04 PM   #10
Re: Acceleration lag..
That sounds like a TPS issue.
Old 06-25-2012, 08:08 PM   #11
Is this it? Performance Chip
Post up the instructions so we can see what they are doing with it.
Old 06-25-2012, 09:00 PM   #12
slow281
sixpac's Avatar
Region: Nebraska
Yepp um ok let me go find them
2001 GT - True Blue
Old 06-25-2012, 09:05 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
this it what it shows.. The sensor is on a stock intake..
Slip it inside there and ran like a champ
2001 GT - True Blue
Old 06-25-2012, 09:09 PM   #14
slow281
sixpac's Avatar
Region: Nebraska
That's what it actually is.. Sorry about the oil been working on the car tonight..
2001 GT - True Blue
Old 06-25-2012, 09:26 PM   #15
Ok, what they are doing is tricking the ECU into thinking that the air temp (IAT= Intake Air Temp) is either warm or cold. I would at first assume warm since they claim better mileage, but I don't know for sure. Since they claim more HP too, it may be tricking it into believing it is cold to add more fuel. Either way it is not a good idea.
The great deal you got on that isn't so good. They charged you $9-$10 for a resistor that you could get at Radio Shack for a few cents.
Research the color code on the resistor and look it up and you will see what they cost. You could probably buy a few hundred for what you paid.
If that made a difference in your car, you probably need to replace the IAT sensor and return that scammer his resistor and get your money back.
Old 06-25-2012, 09:33 PM   #16
slow281
sixpac's Avatar
Region: Nebraska
Yeah but I don't have the iat sensor because of the cai so I couldn't do much else for now.. Ik it's a scam I new that from the start but it made my car run better for now it's a temporary fix till I figure out ware all my problems are...
2001 GT - True Blue
Old 06-25-2012, 09:44 PM   #17
The CAI should have had provisions for that sensor.
If you have been running without it no wonder you are having problems.
You'd be better off with it hanging free in the air than using that resistor.
Old 06-25-2012, 10:02 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
It runs like crap without it. Well I never put the cai on it I'm guessing he went to auto store and bought it peace for peace..
---------- Post added at 11:02 PM ---------- Previous post was at 10:47 PM ----------
What should I do..?
2001 GT - True Blue
Old 06-25-2012, 10:19 PM   #19
What should I do..?
Either drill and tap the CAI for the IAT sensor or just hang it somewhere close free from outside heat sources (i.e. away from headers or engine.). Secure it with some zip ties to keep it from banging around.
If you would, get me a close up of that resistor when you have a chance.
I need to be able to see the color bands clearly.
I'd like to research it and figure out exactly what they are doing with it.
Old 06-25-2012, 10:21 PM   #20
slow281
sixpac's Avatar
Region: Nebraska
Yeah I will tommorrow
But the sensor itself is gone..
2001 GT - True Blue
Old 06-25-2012, 10:25 PM   #21
You should get a new one then.
Old 06-25-2012, 10:56 PM   #22
Those resistors can be a hazard because the CPU doesn't know what's really going on with the engine, so there's no way to control or compensate for faults that are present.
Old 06-26-2012, 07:27 AM   #23
slow281
sixpac's Avatar
Region: Nebraska
Well trust me there is a lot less faults now.. I do believe in fixing things right but at the moment that's not an option..
2001 GT - True Blue
12:59 AM
