Temp sending unit - Mustang Evolution
Old 06-25-2012, 03:14 PM   #1
1Mustang89's Avatar
Temp sending unit
1989 mustang gt, do I have to drain some coolant to change the sending unit?or can I do it without draining since its on top
1Mustang89 is offline   Reply With Quote
Old 06-25-2012, 03:16 PM   #2
just take the cap off. as long as the level is below the unit, then no need to drain.
Old 06-25-2012, 03:18 PM   #3
1Mustang89's Avatar
Take the cap off the coolant?
Old 06-25-2012, 03:28 PM   #4
yeah. your sending unit is on the top of the radiator right? if so then take off the radiator cap and look in there.
---------- Post added at 04:28 PM ---------- Previous post was at 04:27 PM ----------
im sure if it was below it you would have a coolant light on though. mybe you could try to plug the inside with your finger while younpull it off, if its above it and you can reach?
10:06 PM
