Two questons one major consern.. - Mustang Evolution
Old 06-26-2012, 04:31 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
First one.. Is it possible to make the airbag light on my dash go out there is no airbag in my car anymore and I'm not paying 1000$ for a new one and the light blinks an it's super annoying..
Second which I really need help with.. My oil pressure gauge drops to 0 when in idle but the once I put it in gear and hit the gass it goes up.. Then it stays normal until I go out of gear and let it drop back down to idle..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-26-2012, 04:53 PM   #2
jhagan1980's Avatar
Can you not take out the gauge cluster and remove the bulb?
jhagan1980 is offline   Reply With Quote
Old 06-26-2012, 05:40 PM   #3
NeedSomeMods's Avatar
+1 my buddie's '94 GT was the same way.. he just took out the bulb lol
2000 V6 - RIP
The '94 -
NeedSomeMods is offline   Reply With Quote
Old 06-26-2012, 07:32 PM   #4
Gil_T2's Avatar
Re: Two questons one major consern..
Just a thought, if you have a wreck some insurance company's will not cover injury's if you don't replace the air bag.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 06-26-2012, 10:09 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
Didn't think of that one haha but.. Help with oil problem..
---------- Post added at 11:09 PM ---------- Previous post was at 11:08 PM ----------
My insurance knows there is no airbag..
2001 GT - True Blue
Old 06-26-2012, 10:54 PM   #6
The oil pressure dropping to 0 at idle means that your engine bearings (usually main, rod & cam) are worn out and need to be replaced, or that your oil pump is worn out.
When you have to tear the engine apart for this issue you just as well plan on a full rebuild, because if the bearings/oil pump are worn out, so is the rest of the engine.
Old 06-26-2012, 11:18 PM   #7
Struego's Avatar
Before u go into engine rebuilding, and tear down, do an oil change. Take a good look at the drained oil too. If you see any sparkles or shiny metal debris, then it is possible the bearings may be calling it quits. If the oil looks good, and the new oil hasn't changed the way ur gauge is behaving, then you will have to use another oil pressure gauge to check oil pressure with. May be possible that your gauge has an issue. I've seen bad alternators make gauges read wrong too.
Struego is offline   Reply With Quote
Old 06-27-2012, 08:04 AM   #8
slow281
sixpac's Avatar
Region: Nebraska
Will probably end up rebuilding anyway.. But as for now what gauge for oil pressure should I get I see mechanical an electric ones is there a difference? And how do I hook them up.?
2001 GT - True Blue
Old 06-27-2012, 09:12 AM   #9
slow281
sixpac's Avatar
Region: Nebraska
I'm an idiot nvm but I don't know how to hook it up
2001 GT - True Blue
Old 06-27-2012, 09:36 AM   #10
Get a mechanical gauge so you can be sure it is correct. You will connect it at the oil pressure sending unit using a 1/4" pipe nipple and tee so you can leave your dash gauge connected too.
Old 06-27-2012, 09:52 AM   #11
slow281
sixpac's Avatar
Region: Nebraska
Will that come with the gauge or will I have to buy that?
2001 GT - True Blue
Old 06-27-2012, 10:04 AM   #12
No, you will have to buy the fittings separately.
Old 06-27-2012, 10:27 AM   #13
slow281
sixpac's Avatar
Region: Nebraska
Ware can I get those
2001 GT - True Blue
Old 06-27-2012, 02:31 PM   #14
Menards, home depot, etc etc
Old 06-27-2012, 02:39 PM   #15
slow281
sixpac's Avatar
Region: Nebraska
That's what I thought.. If anyone has a picture of this setup I would appreciate one..
---------- Post added at 03:39 PM ---------- Previous post was at 03:37 PM ----------
Do you know if the idle and oil pipe have anything to do with each other? Ik I have a small idle problem.. And the pressure is high and steady until the idle drops then it just crashes so I didn't know If one is causing the other problems..
2001 GT - True Blue
Old 06-27-2012, 02:42 PM   #16
The oil pump is driven by the distributor. So the slower the rpms are the less oil pressure. But unless your idling under 4-500 rpm, I don't think it should read zero.
Old 06-27-2012, 02:45 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
It drops to about 8-900 rpms when it's idleing.. After driving it takes a couple seconds to drop to idle and takes a second to come out of idle..
2001 GT - True Blue
Old 06-27-2012, 02:49 PM   #18
8-900 is fine. It should not read zero pressure with what you describe
Old 06-27-2012, 02:50 PM   #19
slow281
sixpac's Avatar
Region: Nebraska
Would it run bad with no oil pressure?
2001 GT - True Blue
Old 06-27-2012, 02:55 PM   #20
It's hard saying.you may not notice the repercussions of the oil issue until something gives. Unless its knocking, etc. But if your asking if that's your idle problem, I doubt it.
Old 06-27-2012, 02:58 PM   #21
slow281
sixpac's Avatar
Region: Nebraska
No I think it's the air idle control just haven't had time to clean it.. What could I clean it with
2001 GT - True Blue
Old 06-27-2012, 04:05 PM   #22
intensive's Avatar
Carb/throttle body cleaner/spray.
intensive is offline   Reply With Quote
12:12 AM
