Starting issues - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 06-27-2012, 02:24 PM   #1
Foxtrot's Avatar
Foxtrot is unknown around these parts
Starting issues
Ok so here's the back story, I had a rolling body that I put an engine in. Got everything all hooked up and trying to start it. It takes a couple tries to get it to start running. Then it runs real high rpms then just dies out again. There is also a noticeable scent of gas from the exhaust. Is it possible that there is not enough air getting in the engine from the throttle body? Also I know this engine was working fine before I put it in because the car it came from was totaled and I had heard it running before getting it? Any help is greatly appreciated.
Foxtrot is offline
Old 06-27-2012, 02:27 PM   #2
sixpac's Avatar
sixpac is unknown around these parts
Make sure you check all your sensors.. Ats-maf-o2-aic-ect.
Horse Power sells cars, Torque Wins Races.
2001 Mustang GT 4.6..
sixpac is online now
Old 06-27-2012, 02:32 PM   #3
Foxtrot's Avatar
Ok will recheck but put in new o2 sensors and the rest should be good already checked them. Will go through 1 more time to play it safe.
Foxtrot is offline
Old 06-27-2012, 02:35 PM   #4
Senior Member
dreamstang is unknown around these parts
Check your timing. And also maybe let the ecu relearn its parameters. You can disconnect the battery and leave the head light switch on for about 15 minutes. Then plug the battery back in. Once you start it give it some time to adjust.
dreamstang is offline
Old 06-27-2012, 02:49 PM   #5
sixpac's Avatar
+1 had that problem with my 2001 and unplugged the battery overnight and ran just fine in the morning..
Old 06-27-2012, 03:07 PM   #6
Foxtrot's Avatar
Alright will try that later tonight thanks for the info
Foxtrot is offline
Old 06-27-2012, 07:02 PM   #7
Foxtrot's Avatar
Ok tried the light switches and still having trouble but I think it's a timing issue so I'll have to get on that. I'll keep you posted.
Foxtrot is offline
Old 06-27-2012, 08:21 PM   #8
Senior Member
the light switch is just to drain any left over voltage in the battery. this should reset the memory.
Old 06-30-2012, 01:01 PM   #9
Foxtrot's Avatar
Haven't redone the timing yet, just no time (no pun intended). Curios though, on my vaccum tree I only hooked up my intake and master brake cylinder to it. I have no vaccum canister hooked up to it. Would this cause any problems?
Foxtrot is offline
Closed Thread
09:48 AM
