What do you think... - Mustang Evolution
Old 06-28-2012, 10:41 AM   #1
Blackbeauty95's Avatar
-BBK SSI intake manifold kit,w/fuel rails..$350 looks brand new!
-Trick Flow intake manifold,i have two,both upper and lowers in excellent condition $350 each
Soooo my question is A) does the price sound alright? B)Would this setup go good with the explorer heads i plan on installing?
Blackbeauty95 is offline   Reply With Quote
Old 06-28-2012, 11:12 AM   #2
Quball19's Avatar
Well you will get alot of negative on bbk ssi, I have one and like it, most will tell you trick flow would be way to go, all in your choice. Trick flow is good ... Just saying
Quball19 is offline   Reply With Quote
Old 06-28-2012, 12:17 PM   #3
Whats wrong with the bbk?
Old 06-28-2012, 12:22 PM   #4
Quball19's Avatar
Well they had fuel leaks, some say they are restrictive, wont fit under stock hood, oil issues. But hey I like mine no problems, fixed
Old 06-28-2012, 12:28 PM   #5
I wonder how much of an advantage the trick flows will have over the explorer intakes
Old 06-28-2012, 12:35 PM   #6
Quball19's Avatar
Sorry can't answer that... Not trying to deter you from bbk like I said mine works great, they are good.
Old 06-28-2012, 02:48 PM   #7
I would get the number off bbk and call them. Because I heard they solved the fuel leak problem. But if its and older model then it may still have that issue.
I like the looks of the bbk. But I think either choice would be sufficient for gt40 heads. If you ever plan on upgrading your heads to trickflow, I would definitely go with the matching intake.
Old 06-28-2012, 05:35 PM   #8
Thanks guys sounds like i should probly go with the trick flows then!
Old 06-28-2012, 05:54 PM   #9
Quball19's Avatar
That is a good choice too. Enjoy it
12:32 PM
