swiching a 95 from auto to stick. what do i need? - Mustang Evolution
Old 02-17-2008, 11:21 AM   #1
wadman's Avatar
i have a 95 i want to switch from auto to stick. i will rob every thing i can from my 86. but what will i need that is not in my 86. all i can think of is the clutch pedal setup. what am i missing that will not be the same? thanks
wadman is offline   Reply With Quote
Old 02-17-2008, 03:27 PM   #2
Re: swiching a 95 from auto to stick. what do i need?
i think the ds yoke is different and not sure on the bellhousing. some say the input shaft is different but i am not sure on that as well. you need to get the rear wiring harness as well and a new computer etc etc probably cheaper to sell the car and buy a manual
Old 02-17-2008, 06:33 PM   #3
wadman's Avatar
it already has a 86-93 painless weiring harness in it. the ds will be coming out of the 86 and there is a built 347 in it the 86 that is why i want to put it in the 95. is the drive shaft yoke longer in the 95?
Old 02-17-2008, 06:59 PM   #4
i am not sure, i remember getting my aluminum ds in my 01 and i think from 94-04 is the same but ai am betting the fox ds is shorter the good thing is both have a gear driven odometer so that will work for you (but the speedo gear may be off its cheap though) the cluch size might differ, my 01 had an 11 inch clutch i think but you will have to buy a flywheel anyway probably.
Old 02-17-2008, 07:28 PM   #5
wadman's Avatar
on another forum they said i cant use the trany. but i have a tremec tko. i am trying to look it up now i relay hope it fits.
6speed stick in a v6 Ninethourpm Pre-2005 V6 Mustang 29 06-28-2009 08:55 AM
Automatic-to stick The Darkside 2005-2010 Mustang GT 8 12-07-2008 04:48 PM
Stick or Auto for the v6 BulletWalker Pre-2005 V6 Mustang 12 03-19-2008 06:00 PM
drove a stick oaktonarcher The Bar 33 07-20-2004 04:30 AM
Got stick in corners? Jayber The Bar 4 07-12-2004 06:20 PM
01:59 PM
