Originally Posted by fast 94 5.0 Soooo I need min 42lbs injectors lol..i guess I need to do n upgrade ---------- Post added at 12:53 AM ---------- Previous post was at 12:51 AM ---------- Im at 30 now n my friend who has a boosted stang says go straight to 62lb n booossttt lol |
Yes, you should to keep from running lean and burning a piston or 8.
I would definitely think ahead and size them for future mods to keep from having to buy new ones later. You should be able to have it tuned or tune it yourself with a PMS/Wideband to make most sizes work.
I'm going with 60 lb injectors (Siemens DEKA) right off the bat with my SC install.
At 405 NA HP adding 8 lbs of boost should put me in the 600+ HP range, so I need to be sure I can feed those hungry ponies. I'm tuning mine with the PMS and a Wideband as I can't see paying a shop to do something I can do myself. The PMS is expensive, BUT in lieu of paying a shop I will still have something to show for my money spent and I can change the tune whenever it is necessary without going back to a shop.
P.S. Once you get close to 500 FWHP (Flywheel HP) you need to further modify your engine to withstand the HP. See the Superchargers & Turbos sticky thread for tips.
