New block or rebuild? - Mustang Evolution
Old 07-01-2012, 10:22 AM   #1
slow281
sixpac's Avatar
Region: Nebraska
M pulling the motor out of my car once she gives in but I'm wondering costs of both options ik a place ware I can get a brand new block
For about 700$ what would it cost to have someone rebuild it..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-01-2012, 03:33 PM   #2
WhiteCobra94's Avatar
If your getting a brand new if go with a aluminum block if your getting a remanufactured block, www.50resto.com sells budget blocks , bored .30-.60 over for $800
Old 07-01-2012, 04:01 PM   #3
You can pic up a complete short block for that price if all you want is a stock rebuild. Pull your heads and intakes, clean and inspect and swap them and all accessories to new motor. Should be able to do it in a weekend with hand tools
Old 07-01-2012, 04:19 PM   #4
yeah but i would stay away from anything close to .060 over
Old 07-01-2012, 05:15 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
I just want the block.. The heads and everything should be ok..
---------- Post added at 06:15 PM ---------- Previous post was at 06:12 PM ----------
I would maybe do .030 over but idk it's just a cruzer so I'd probably stay stock.. What's it cost to take mine in and have it rebuilt.?
2001 GT - True Blue
Old 07-01-2012, 05:28 PM   #6
If you have a stock block. No reason to go 030 over. That is just to clean up the piston walls etc.
Old 07-01-2012, 05:41 PM   #7
slow281
sixpac's Avatar
Region: Nebraska
Well that's probably what I need.. New bearings and seals all the way around and was wondering what the cost..
2001 GT - True Blue
Old 07-01-2012, 05:53 PM   #8
i havent done to many full rebuild, so i cant tell you for sure. your gonna have to contact your local machine shop and ask them how much to freshen up the cylinder wall, and magna flux the block.
Old 07-01-2012, 06:04 PM   #9
deadsp0t's Avatar
IMO once past .30 over will not be as reliable as a DD
That's unimpressive
Old 07-01-2012, 06:07 PM   #10
exactly. you will weaken the cylider walls and thin them out with risk of running hot all the time.
Old 07-01-2012, 07:07 PM   #11
slow281
sixpac's Avatar
Region: Nebraska
It would every be a daily driver but.. I would mind to take her out on trips sometimes
2001 GT - True Blue
Old 07-02-2012, 01:09 AM   #12
Re: New block or rebuild?
Stop and consider exactly what you want to do with the car AND if you ever think you may want to use nitrous or forced induction.For most purposes a stock shortblock will be just fine, but if you desire to use nitrous or forced induction, then an aftermarket block is strongly recommended.
When buying a pre-assembled shortblock you want to be sure to do so from a trusted vendor. I can't tell you how many times in the past I have found defects, non matching rods or pistons, out of spec bores, rings installed wrong, rods installed wrong and many other sloppy and improper rebuild issues. (They count on most people NOT checking for these shoddy building practices.)
Do not buy any shortblock that has been bored over .030". Cast iron blocks are poured into sand molds and sometimes the molds slip. Ford set the .030 overbore max to ensure that the cylinder walls do not become to thin during rebuilds. If the block mold has slipped, an overbore to .040" - .060" will dangerously weaken the cylinder walls and lead to overheating or breakage.
IMO, you would probably be better off if you rebuild the engine you have.
Old 07-02-2012, 08:31 AM   #13
My block is bored .40 over and I have no issues!
Old 07-02-2012, 08:43 AM   #14
A lot of times you can get by just fine, but if you really start putting the pressure to it, it is likely to fail or overheat at some point.
If you check for core shift and have the block sonic tested to ensure the cylinder walls are thick enough you can go as much as .060" overbore. I have done that back in the 80's and the engine held up ok, but every time it was ran hard it would overheat. You could actually open the throttle and watch the heat gauge climb at the same time. The blocks were poured using a thinwall casting technique (done to save weight) that makes them weak to begin with and over boring past the recommended .030" is just not a good idea.
Old 07-02-2012, 10:47 AM   #15
slow281
sixpac's Avatar
Region: Nebraska
I don't believe in nitrous.. And I Dought I will ever use forced.. Do you know the average cost to take it in and have someone rebuild it? I can pull it and everything but I can't tear to deep into her..
2001 GT - True Blue
Old 07-02-2012, 10:49 AM   #16
Usually you can get it done under 1000$ but every area/shop varies so much, no one on here could give you a good estimate. I would just get on the phone and see. Let us know what they say.
Old 07-02-2012, 10:55 AM   #17
Originally Posted by sixpac View Post
I don't believe in nitrous...
I do, especially at the dentist's office.
Old 07-02-2012, 11:23 AM   #18
slow281
sixpac's Avatar
Region: Nebraska
Haha lmao.. I feel like if the system is not set up perfect it can really destroy a motor..
2001 GT - True Blue
Old 07-02-2012, 07:14 PM   #19
That's very true. What I don't like is having to constantly mess with filling the bottles. Other than that you can't beat the cost for a power adder.
Old 07-02-2012, 10:33 PM   #20
slow281
sixpac's Avatar
Region: Nebraska
No, but I'm also not a power guy, I like clean luxury with some hourseys under the hood..
2001 GT - True Blue
Old 07-02-2012, 10:46 PM   #21
You might have chosen the wrong car then.
Luxury & Fox Body, just do not fit together.
Old 07-02-2012, 11:09 PM   #22
slow281
sixpac's Avatar
Region: Nebraska
I'm using luxury vaugely.. I mean more like ugh beauty? I love the power these things can put out but let's face it I don't have a track within 100 miles of me.. So I want something I can take out on the weekends ect. Beautiful paint witha perfect interior. And at the end of the day still be able to light up the tires..
2001 GT - True Blue
Old 07-03-2012, 12:00 PM   #23
Bily Pepp's Avatar
I'm considering rebuilding my 302 block, nothing is wrong with it. Runs smoothly, no knocks, no nothing. I just want to ensure that the entire engine is clean, and sludge free.
Bily Pepp is offline   Reply With Quote
Old 07-03-2012, 02:02 PM   #24
slow281
sixpac's Avatar
Region: Nebraska
Get prices!? Lol
2001 GT - True Blue
09:49 AM
