MAF question - Mustang Evolution
Old 07-02-2012, 09:11 AM   #1
captain78's Avatar
MAF question
The black plug that screws on to the MAF is that the sensor or is it just something that plugs into the sensor
captain78 is offline   Reply With Quote
Old 07-02-2012, 09:13 AM   #2
captain78's Avatar
Here's a pic. Of the black thang I was talking bout. Somebody is telling me that the black thing that bolts to the maf is the sensor
Old 07-02-2012, 09:26 AM   #3
Re: MAF question
Yes, that houses the sensor and electronics.
On newer cars, they keep the sensor and just change the tube it is mounted in to increase size.
Old 07-02-2012, 09:37 AM   #4
captain78's Avatar
Ok cause I was told that it's a stock maf sensor. I was told buy the guy when I bought it that it was a 75 mm maf set for 24 lbs injectors you can see by the chrome that it's not stock. Could we both be right idk
Old 07-02-2012, 09:48 AM   #5
Re: MAF question
It doesn't look like a stock one to me, but who knows for sure.
The injector size programming is usually (or it used to be) scribed into the plastic on top.
Measuring it and converting to MM will tell you if the size is correct.
Did you get any paperwork or is there a name and part number on it?
Old 07-02-2012, 09:55 AM   #6
captain78's Avatar
On the black piece it says ford
---------- Post added at 09:52 AM ---------- Previous post was at 09:52 AM ----------
Nothing on housing
---------- Post added at 09:55 AM ---------- Previous post was at 09:52 AM ----------
There is a tube inside the housing it looks like there's a way to take it off
Old 07-02-2012, 10:06 AM   #7
Re: MAF question
Nothing on housing
Well it's evidently a Ford sensor. Probably off of a newer vehicle.
I'm surprised it doesn't have any numbers on it.
Old 07-02-2012, 10:20 AM   #8
captain78's Avatar
It might I just can't pop the hood ATM the car is 5 ft in the air getting exhaust put on
« gears?? | Oil gauge »
01:54 AM
