bad vibration - Mustang Evolution
Old 02-19-2008, 07:13 PM   #1
bad vibration
Im working on a 94 mustang 5.0 that has a very bad viberation at idle and when reved up when coming back down shakes very bad i mean ever thing on car shakes any ideas?
dodgeman340 is offline   Reply With Quote
Old 02-19-2008, 07:37 PM   #2
wiarumas's Avatar
Re: bad viberation
are the RPMs steady at idle or does it fluctuate a bit up and down?
Old 02-19-2008, 07:43 PM   #3
Re: bad viberation
sounds like the idle is to low, does it have a cam, what does it idle at?
Old 02-19-2008, 09:20 PM   #4
Re: bad viberation
the engine shakes like it has a bad miss but doesnt like some in the engine isnt balanced .compression is good plugs and wires is good
Old 02-19-2008, 09:39 PM   #5
MonteCitan's Avatar
Re: bad viberation
Pull the cap off the rotor and make sure all the contacts look fine, make sure the rotor looks good, pop the rotor out make sure the locating tab isn't snapped or cracked
check fuel pressure if you can, an injector could be bad... --
check around the balancer, make sure nothing is loose or cracked/hanging out, try taking the drive belt off (you can run it for a minute or two this way) see if it still vibrates badly..
Could also be a cracked or warped pressure plate/ flywheel
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-19-2008, 10:19 PM   #6
Y2E0L0L5OGWT's Avatar
Re: bad vibration
My guess was also going to be a possible fuel flow problem similar to what Monte said above...I was thinking a fuel pump or injector issue....
Sounds to me like you could possibly be having a fuel problem causing the whole motor or just a cylinder to be running way lean and that's making the terrible vibrations...
Old 03-17-2008, 10:38 AM   #7
Re: bad vibration
mine had the same problem last year. It ended up being the harmonic balancer
-Doug
'95 Mustang GT
Rocket50 is offline   Reply With Quote
Old 03-18-2008, 07:47 PM   #8
silverstangboy's Avatar
Re: bad vibration
good point rocket 50!
a basic cyclinder balance test will tell you right away if its a mechanical problem, if everything checks there I would look at engine balance (clutch problem, balancer bad, flywheel out of spec.)
you can do this two ways, either from the computer via Koer and hit the throttle quickly OW, or the old fashioned and my favorite, a pair of insulated plyers and a tachometer record the drop in rpms as you disconnect each cylinder, the lowest drop is your strongest cylinder. a bad cylinder will have nearly no drop at all.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-19-2008, 08:22 AM   #9
wiarumas's Avatar
Re: bad vibration
alternatively you can just overpower the bad vibrations by listening to the beach boys good vibrations really loudly.
? Wheel Vibration 08 GT skully 2005-2010 Mustang GT 14 10-27-2009 09:05 AM
vibration spw1001 1979-1995 Mustang GT 7 10-04-2008 01:21 PM
Weird Vibration Jeremym831 1996-2004 Mustang GT 2 01-08-2008 07:32 AM
Sound Vibration megax29 Mustang Audio & Video 14 04-04-2006 09:21 PM
01:17 PM
