no power to a/c compressor . - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 1979-1995 Mustang GT
Closed Thread
Old 07-05-2012, 10:02 AM   #1
91fun is unknown around these parts
Jumped and clutch works. Only one wire has power at relay? Any suggetions? Thanks
91fun is offline
Old 07-05-2012, 11:45 AM   #2
Senior Member
Trojan Horse is just getting started.
Re: no power to a/c compressor .
Check your fuses and trace the wiring to be sure it isn't damaged or broken.
If you do not have one a Chiltons Manual with the wiring diagrams is a big help.
Trojan Horse is offline
Old 07-05-2012, 11:56 AM   #3
Checked fuses, wires look fine. I have manual book. Relay only has power at red wire. Do you know anything about saftey switch on clutch pedal.. Was told that can be a issue but how?
91fun is offline
Old 07-05-2012, 11:58 AM   #4
Senior Member
The safety switch on the clutch pedal just keeps you from starting the car without pushing in the pedal first.
Not sure how that could affect it, trace the wires out in the manual and see how they are connected.
Old 07-05-2012, 12:11 PM   #5
Thats what i thought also. I will look. Can you tell if relay is bad with test light ? When i re did fuel pump i checked relay first and it clicked . Ac relay dont. And relay for fuel pump was good
91fun is offline
Old 07-05-2012, 12:31 PM   #6
Senior Member
Yes you can. If it doesn't let power through the contacts then likely the relay coil is burned out.
Old 07-05-2012, 01:11 PM   #7
Ok book shows red blue wire from saftey switch to starter relay. Little wire with boot on solenoid. No power.. I have no clue. There is a adjustment on saftey switch. Moved it and couldnt start car. Moved it back and car started... ?? Thanks for your help
91fun is offline
Closed Thread
09:26 AM
