07-06-2012, 04:56 PM
#1 | | Registered User
| won't start
Maybe this isn't the right place to look but I've looked everywhere else. I have an 88 lx that I swapped in a 2.3 Turbo. I can't get power to the engine. All my lights, wipers, windows and what not work. I turn the key on my normal dash lights come on, but the fuel pump doesn't come on, the key won't turn it over(it turns over if I cross the solinoid but still won't start) and no power to the ignition. I don't know what else to check, but I know it's something simple just can't figure it out. I know the pros here can help out.
__________________ |
07-06-2012, 05:12 PM
#2 | | Senior Member
as long as you have around 12.5 volts in at the battery, its gonna probably be a bad wire/ground.
07-06-2012, 05:15 PM
#3 | | Registered User
Ok thanks I'll have to check everything again. I just put a new ignition switch in and new ground wires. Any ideas where to start looking
07-06-2012, 05:20 PM
#4 | | Senior Member
i would start from the battery. chase the wires from there to alternator, starter silinoid, and ignition etc. i would follow the wireing diagrams in the back of your haynes/chilton. also you should have a good ground from the battery to the motor and to the chassis.
did you just redo the wires you talk about? if so i would check there also.
07-06-2012, 05:22 PM
#5 | | Registered User
I have good ground. I have power to everything but what needs it to start and run
07-06-2012, 05:25 PM
#6 | | Senior Member
hmm.... you said it cranks when you jump the silinoid? but the fuel pump doesnt run?
07-06-2012, 05:27 PM
#7 | | Registered User
Yes it cranks if i cross the solinoid.No, the fuel pump works if I hard wire it but not with the key and no ignition.
07-06-2012, 05:28 PM
#8 | | Senior Member
your gonna have to look at your wiring schematic and trace all the things that dont have power and see if there is a common area they share.
07-06-2012, 05:30 PM
#9 | | Registered User
Cool thanks
07-06-2012, 05:31 PM
#10 | | Senior Member
i dont know much about the 2.3, but on a 5.0 the fuel pump will prime for 2 seconds when you turn the key forward. then it will run via a signal from the tfi module aka ignition module. the ignition module sends the signal to the ecu, then the ecu will send a ground signal to the fuel pump relay triggering it to turn the the pump on.
07-06-2012, 05:32 PM
#11 | | Registered User
Yea it doesn't kick on art all
07-06-2012, 05:36 PM
#12 | | Senior Member
well, can you hear the fuel pump relay trigger? ot will make a clicking noise usually. i would check power at the relay. and you can trace wires from there to.
07-06-2012, 05:38 PM
#13 | | Registered User
I can here the relay click but nothing after that
07-06-2012, 05:48 PM
#14 | | Senior Member
if the relay is clicking, use your schematic and check the proper wires in and out of the relay. and voltage at the pump. ---------- Post added at 06:48 PM ---------- Previous post was at 06:41 PM ---------- if im not mistaken the relay will have a constant 12 volts, a ignition 12 volts and a ground and signal wire. if the relay is triggering but no power is going to the pump. the wire that supplies the power maybe linked to the other issues.
07-06-2012, 10:46 PM
#15 | | Senior Member
| Re: won't start Quote:
Originally Posted by BigRed1781 Maybe this isn't the right place to look but I've looked everywhere else. I have an 88 lx that I swapped in a 2.3 Turbo. I can't get power to the engine. All my lights, wipers, windows and what not work. I turn the key on my normal dash lights come on, but the fuel pump doesn't come on, the key won't turn it over(it turns over if I cross the solinoid but still won't start) and no power to the ignition. I don't know what else to check, but I know it's something simple just can't figure it out. I know the pros here can help out. | There are probably some discrepancies in the wiring.
You will need to cross reference between the donor car and your car to see what the differences are.
I'm betting the wiring from the switch to the engine harness may be slightly different.
07-06-2012, 10:52 PM
#16 | | Registered User
The engine harness is the harness from the Mustang. All the plugs are the same from the TC to the Mustang.
07-06-2012, 11:19 PM
#17 | | Senior Member
Originally Posted by BigRed1781 The engine harness is the harness from the Mustang. All the plugs are the same from the TC to the Mustang. | Something is not right if you are not getting voltage to the ignition and the solenoid, so there is an issue somewhere in there. Trace the wires back from the solenoid and ignition to ensure they are connected correctly and getting fire when your turn on the switch. If it is not the wiring then the switch would be suspect.
07-06-2012, 11:30 PM
#18 | | Registered User
Just put a brand new ignition switch today torjan. I heard back from stinger Performance, rather quick to I might add. They said the wires changed the egr wires to the vam wires. Everything worked fine before I did the swap.
07-07-2012, 02:55 PM
#19 | | Registered User
Mine did that to the first time went to start it so we traced wires back and low and behold the guy I bought the car from had put a alarm system in the car at some point with a starter disable on it. Just some else to put out there.
07-07-2012, 03:04 PM
#20 | | Senior Member
Originally Posted by BigRed1781 Just put a brand new ignition switch today torjan. I heard back from stinger Performance, rather quick to I might add. They said the wires changed the egr wires to the vam wires. Everything worked fine before I did the swap. | Little slow today, not understanding what you are telling me.
What wires changed and what is vam wires?
07-08-2012, 10:21 AM
#21 | | Registered User
The VAM meter is the precursor to the mass airflow meter. I had to use the wires that originally went to the egr & use them 2 wire in the vam.
07-08-2012, 08:41 PM
#22 | | Senior Member
Originally Posted by BigRed1781 The VAM meter is the precursor to the mass airflow meter. I had to use the wires that originally went to the egr & use them 2 wire in the vam. | Ok, you used the EGR wires to wire in the VAM, where do they go on the other end?
I can't see the ECU using a signal from the VAM in the same way as it does a signal from the EGR.
07-09-2012, 08:55 AM
#23 | | Registered User
The Thunderbird didn't have an egr sensor. The mustang egr wires go to where the vam wires go in on the TC brain. I had to move one wire on the harness at the brain. I followed the instructions from stinger-performance to the letter, and I know someone that had done the same with no problems. I'm taking it to a Guy that specializes in car wiring. I know he can figure it out.
07-09-2012, 02:50 PM
#24 | | Registered User
Would it be possible that a low oil sensor would keep it from getting power to the starter, fuel pump, & ignition? Oh yea you have to think of it as TC as the motor & brain come from a TC
07-09-2012, 09:45 PM
#25 | | Senior Member
Originally Posted by BigRed1781 Would it be possible that a low oil sensor would keep it from getting power to the starter, fuel pump, & ignition? Oh yea you have to think of it as TC as the motor & brain come from a TC | I never knew a low oil sensor to do anything other than turn on a light, but I suppose it is possible that if it senses the oil as being to low that it would prevent the engine from starting if the ignition is wired through it.
That's why I was saying you should trace the wires either manually on the vehicle or in the books, so you know what the ignition and starting wires run through before they get to their destination.
07-10-2012, 05:15 PM
#26 | | Registered User
So I did some digging, I think the ecu maybe bad. From what I read if the check engine light comes on when the key is turned it means the ecu is getting power. I tried to get it to do a self test & nothing. It doesn't throw any codes, from what I understand that means the brain is bad. Any input?
07-10-2012, 05:26 PM
#27 | | Senior Member
Originally Posted by BigRed1781 So I did some digging, I think the ecu maybe bad. From what I read if the check engine light comes on when the key is turned it means the ecu is getting power. I tried to get it to do a self test & nothing. It doesn't throw any codes, from what I understand that means the brain is bad. Any input? | Sounds reasonable if you cannot get it to communicate.
07-20-2012, 03:50 AM
#28 | | Registered User
So I put a new ecu in & still nothing so I'm gonna drop the steering column out & start checking wires
07-20-2012, 11:09 AM
#29 | | Senior Member
Originally Posted by BigRed1781 So I put a new ecu in & still nothing so I'm gonna drop the steering column out & start checking wires | That would be a good idea.
You can fry the ECU easily if the wiring is not correct.
07-20-2012, 01:35 PM
#30 | | Registered User
So I used the multi meter & my eec relay is sending ground through instead of positive. Any ideas why? I have checked all the wires coming from the ignition switch & they all check out. All the wires have the signal they are supposed to. I'm stumped.
07-20-2012, 01:55 PM
#31 | | Senior Member
Originally Posted by BigRed1781 So I used the multi meter & my eec relay is sending ground through instead of positive. Any ideas why? I have checked all the wires coming from the ignition switch & they all check out. All the wires have the signal they are supposed to. I'm stumped. | Maybe it is supposed to?
You will have to research your particular application and see what the pin out is.
07-20-2012, 02:37 PM
#32 | | Registered User
So I found one problem. One of the fusible links was grounded. Switched it to positive & now my fuel pump kicks on with the key, I have spark but still won't turn over with the key. I cross the solinoid it will turn over & pop a lil but won't fire. Check my plug wires & firing order & everything checks out. I'm getting closer though.
07-20-2012, 02:51 PM
#33 | | Senior Member
| Re: won't start  Good luck getting it going.
Not being right there makes it difficult to help, but we'll do the best we can.
07-21-2012, 01:46 PM
#34 | | Registered User
Got it figured out. Fusible link for the ecu was grounded. Starts up just fine.
07-21-2012, 03:40 PM
#35 | | Senior Member
Originally Posted by BigRed1781 Got it figured out. Fusible link for the ecu was grounded. Starts up just fine. |  Glad you got it sorted out.
