my 95 saleen clone for the drag strip and street - Mustang Evolution
Old 02-21-2008, 10:43 AM   #1
wadman's Avatar
this is my 95 saleen clone. it will be ready shortly for the drag strip, street racing or cruising.
this car is far from done. but i thought you might enjoy taking a look. let me know what i am missing or what you think the car needs.
x
x
x
x
1. My 1995 Mustang
2. _______________
3. ENGINE
4. 347 stroker is going in
5. __________________
6. IGNITION
7. Car Also Has Painless Wiring For 89 Electronics
8. Has Anderson Switch Panel
9. Wired For Electric Water Pump
10. Electric Fan
11. Line Lock
12. Battery Relocated To Trunk 1 Gauge Wire
13. Flaming River Big Battery Switch
14. _________________
15. EXHAUST
16. Bassini off road x pipe
17. Flowmasters
18. _________________
19. DRIVETRAIN
20. 8.8 Rear With 3.73 Gears
21. 33 Spline Moser Avxles
22. 33 Spline Strange Spool
23. Ta Girdle And
24. Stud Kit
25. New Bearings
26. Seals
27. Tubes Welded
28. Rear Has 9" Ends
29. Safety loop
30. ____________________
31. TRANSMISSION
32. not in yet
33. Tremec TKO
34. Tremec bell housing
35. McCloud clutch
36. ____________________
37. SUSPENSION
38. Front Suspension Anthony Jones K-Member
39. A-Arms
40. Coil Overs Tokico Adj. Drag Struts
41. Upr Caster Camber Plates
42. Upr Coil Overs front
43. Flaming River Manual Rack Kit
44. Lakewood 50/50 Shocks
45. With Coil Over Kit rear
46. Torque Boxes Are All Reinforced With Wild Rides Battle Box Kit
47. Rear Has Double Adjustable Upper Control Arms And
48. Mega Byte Jr Lower Control Arms
49. Steering Shaft
50. ___________________
51. EXTERIOR
52. New Blue Paint
53. Real Saleen Ground Effects and Wing
54. Cobra R Hood (Cervini)
55. New Head Lights
56. _______________________
57. WHEELS
58. Not yet
59. ____________________
60. BRAKES
61. Front and Rear Cobra Disc Brakes
62. Braided Brake Lines
63. Crossdrilled Slotted Rotors
64. Line lock
65. ____________________
66. INTERIOR
67. B&M Hammer Shifter (coming out)
68. New Black Carpet
69. No Factory Gauges All Auto meter
70. Fuel Level
71. Speedo
72. Tack
73. Shift Light
74. Low Oil Warning
75. Engine Temp
76. Trans Temp
77. Oil Temp
78. Boost/Fuel Pressure
79. Voltage
80. Oil Pressure
81. Braided Line For Oil Pressure Gauge
82. Has New Ignition Switch
83. New Carpet In Trunk
84. Door Locks
85. New Power Trunk Release
86. New Trunk Lock
87. Sill Plates
88. ______________________
89. AUDIO
90. New Alpine Radio
91. Polk Speakers
92. _________________________
93. FUEL
94. Aluminum 15 Gallon Fuel Cell
95. Fuel Level Sending Unit
96. Roll Over Vent
97. All Braided Fuel Lines Are In Car #10 Feed #8 Return Fittings
98. All Attached Just Need Pump and Regulator
99. _____________________
100. SECURITY
101. Not yet
102. ________________________
103. ENGINE BAY DRESS UP
104. Painted and cleared
105. ________________________
106. EXTRAS
107. Roush Tool Kit In Trunk
108. Sub Frames Connecters Welded In
109. Wired For Trans Brake
110. Pia Headlight Bulbs
111. All New Bulbs /Fuses/ Heater Core/ Headlight Switch New Parking Brake Cables
112. Under Car Is Also Pained Same Color And Clear Coated
Name:	red stang blue stang and talon 035.jpg
ID:	18726   Click image for larger version
Name:	red stang blue stang and talon 034.jpg
Name:	red stang blue stang and talon 033.jpg
ID:	18728   Click image for larger version
Name:	red stang blue stang and talon 038.jpg
wadman is offline   Reply With Quote
Old 02-21-2008, 10:52 AM   #2
wiarumas's Avatar
Re: my 95 saleen clone for the drag strip and street
that must have been pricey!
very nice!
i think the only thing you may need now is some rims and tires.
Old 02-21-2008, 10:59 AM   #3
wadman's Avatar
there is well over 15 grand in this car with no motor and no trany. i did not pay any where near that tho.
i want to get 18x10 saleen clone rims for it for the street with some drag radials. do you think they would fit ok with how much this car is going to squat when i launch it.
Old 02-21-2008, 01:35 PM   #4
Kiljosh's Avatar
Well you have the rear coilover kit so I don't think it really matters. Jack it up all the way the first run and back it down slowly after every run. If you shred a tire your night is over but then atleast you know where your sweetspot is.
First time at the Drag Strip SC_STEEDA General Mustang Discussion 17 06-12-2008 03:30 PM
Another trip to the drag strip: MarkuzLS1 The Bar 23 03-06-2007 09:51 PM
Drag strip trip? MarkuzLS1 The Bar 2 09-30-2005 12:13 PM
drag strip... Fishers Stang Regional Mustang Discussion 0 05-20-2004 07:41 PM
08:54 AM
