RPM's hanging - Mustang Evolution
Old 07-07-2012, 06:17 PM   #1
rwsmith3623's Avatar
RPM's hanging
Car is idling at around 1k, which seems higher than normal, also at idle when I step on it a little, or any at all for that matter the rpms hang there for quite awhile. I'd say 3-4 seconds. I moved awhile back so I had to get in contact with a new shop, took it there and they say it's doing it because it's running pretty lean an it needs tuned. Just wanted some feed back on what you guys thought before I pay 700 to get it retuned. I just had it tuned about 11 months ago. With that being said I just got back from deployment so it sat for about 8 months. What do you guys think?
rwsmith3623 is offline   Reply With Quote
Old 07-07-2012, 06:28 PM   #2
Clean and adjust iac,maf, and tps.
There is a good article in the useful mustang Info thread in the sticky section that covers the infamous hanging/surging idle.
Old 07-08-2012, 06:20 AM   #3
Re: RPM's hanging
I'd find a different shop. Sounds like they just want to rip you off to me.
If it isn't forced induction or nitrous fed, then you don't need a $700 "tune".
That's almost the cost of an AFM PMS piggy back tuner and with one of those and a Wideband you could tune it yourself as needed without it costing you several hundred dollars each time.
Follow dreamstangs suggestions and you can probably work it out.
Old 07-08-2012, 09:54 AM   #4
It is forced induction. I run a v4 x-trim. I'll follow what dreamstang said. However, even if it does end up needing tuned, 700 seems crazy. My old shop National Speed would give whatever dyno time necessary, and a custom 4 tune for $500 flat. Seems most shops normally charge 5-600.
Old 07-08-2012, 08:31 PM   #5
Re: RPM's hanging
To me even that is excessive, which is why I bought the PMS and I'm going to get a Wideband to go along with it. At around $1200 I'd be approximately at the cost of 2 shop tunes, then from there on out any tuning I need to do will essentially be free and I will be able to monitor and make corrections as I need to, instead of finding out the hard way that the engine is out of tune and damaging something.
Old 07-08-2012, 08:38 PM   #6
i agree. i hear of people getting dyno tunes all the time for 4-500$. im not sure if i ever even heard of someone paying that much unless itminclude more parts.
07:12 AM
