check out this STOCK throttle body! - Mustang Evolution
Old 07-09-2012, 07:31 PM   #1
mustangbill00's Avatar
The previous owner removed the innerds or the stock throttle body lol! Could this have been the cause of my engine stalling out when I come to a stop? What other issues might this create?
mustangbill00 is offline   Reply With Quote
Old 07-09-2012, 07:36 PM   #2
Forum Car Trader
90GTNovi2000's Avatar
Is that the MAF?
90GTNovi2000 is offline   Reply With Quote
Old 07-09-2012, 07:37 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
That's the MAF sensor and yes that's a problem
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-09-2012, 07:41 PM   #4
Lol oops! Wrong part on my mind.
---------- Post added at 07:41 PM ---------- Previous post was at 07:38 PM ----------
How would this effect the motor?
Old 07-09-2012, 08:46 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
Tells how much air the car needs to suck.. It is a major part..
2001 GT - True Blue
Old 07-09-2012, 09:15 PM   #6
I know what it does, I was just wondering what kind of running issues it would cause. Thanks for the reply though.
Trojan?
---------- Post added at 09:15 PM ---------- Previous post was at 09:10 PM ----------
Actually I think it tells the CPU how much air is coming into the motor, then fuel, timing ect... is adjusted from there. Something like that lol
Old 07-09-2012, 09:20 PM   #7
slow281
sixpac's Avatar
Region: Nebraska
Trojan?
Well yes but without it working the motor does not no how much air to suck cause yes the problems idling running slowing down everything gas mpg drop. Just about anything..
2001 GT - True Blue
Old 07-09-2012, 09:28 PM   #8
Probably the reason it only gets around 16mpg on a mildly built 302, and it always smells like its running rich? I've got a 70mm on the way so I'm not really worried about it.
Old 07-09-2012, 09:30 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
70mm MAF sensor?
2001 GT - True Blue
Old 07-09-2012, 09:34 PM   #10
Lol yeah, and 24lb injectors and 75mm throttle body.
Old 07-09-2012, 09:35 PM   #11
slow281
sixpac's Avatar
Region: Nebraska
Wow you get 17 mpg?? He'll I've gone 70 miles on a tank of gass lol but I've been working and test driving none stop.. It's idled alot
2001 GT - True Blue
Old 07-09-2012, 09:38 PM   #12
70 MILES ON ONE TANK?!?! What did you do to your motor?!?! Lol
Old 07-09-2012, 09:39 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
Well for one the motors like uh..... Well leave it at that.. But it hasn't left town for a month.. So that's 70 miles intown cruzing.. It's painful
2001 GT - True Blue
Old 07-09-2012, 09:46 PM   #14
I guess my 200 or so miles to a tank isn't bad I'm working on a turbo setup right now, so I'm sure that's going to make things even worse....or better, who knows!
Old 07-09-2012, 09:48 PM   #15
slow281
sixpac's Avatar
Region: Nebraska
Well I had all my mods put on hold so I'm fixing things little by little trying to keep her running.. But I have a feeling the motors gonna need rebuilt very soon but I just had to put every last pennie I had into college.. Sucks..
2001 GT - True Blue
Old 07-09-2012, 09:53 PM   #16
Wow that blows! That's good your going to college though. Something I should have done! Is your motor a 5.0? I ask BC your profile name is Sixpack.
Old 07-09-2012, 09:58 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
I have an orange 5.0
She's my baby..
My black one is my DD well kinda.. Because the motors going bad I find myself trying to get every last mile out on my orange one so I drive it every day.. But yeah I'm still going to be doing little diy things and maintance on them but no more mods for a while.. Right before I leave for colledge.. I'm pulling the motor
And having it taking in to a good family ford genius and he's gonna rebuild it over the winter..
2001 GT - True Blue
Old 07-09-2012, 10:09 PM   #18
I need to get another fox again . Mine got wrapped around a tree by my brother.
Old 07-09-2012, 10:14 PM   #19
slow281
sixpac's Avatar
Region: Nebraska
I could be happier with mine.. It's a cobra.. But I want a cobra in the 96-98 style..
---------- Post added at 11:12 PM ---------- Previous post was at 11:10 PM ----------
Well the body and motor are besides the intake I've hot that waiting to put on..
---------- Post added at 11:14 PM ---------- Previous post was at 11:12 PM ----------
Couldnt***
2001 GT - True Blue
Old 07-09-2012, 10:15 PM   #20
Filibuster
The ”honeycomb” screen has been removed obviously,but the maf sensor hot wires are still there at least one from what I can see(there should be two) the other one could just be dirty..I would replace the screen as those hot wires are very delicate and directly affect your a/f ratio and will definitely cause poor gas mileage and performance if damaged:/...also get some maf cleaner too..
Oh and the ”honeycomb” screen helps to direct the airflow to get proper readings with the maf sensor..without it you'll get false readings and improper a/f ratios
XXSTEVEO66 is offline   Reply With Quote
Old 07-09-2012, 10:20 PM   #21
I'm not going to mess with it at this point. Its free if anyone wants it lol.
Old 07-10-2012, 12:14 AM   #22
Re: check out this STOCK throttle body!
That used to be a pretty common mod. The sensor is still there so it should work ok.
I have read that at times you might need to "clock" the MAF for it to read correctly when it has been modified.
Clocking just means to rotate it until you find the position it operates the best in.
If it is free I will take it. Just PM me the cost to send it to 65248 and get my address.
Old 07-10-2012, 12:58 AM   #23
93slowstang's Avatar
Couldnt***
Ok, it's killing me. Beautiful car but nothing about the gt ground effects or spoiler are screaming cobra. I just don't want you being pinned as a poser for something that simple.
Old 07-10-2012, 01:23 AM   #24
Stockish302's Avatar
Damn thats is old school I did that when I was in highschool and then just customized a c&l test tube on it lol good mod for $40 back in the days, damn dominos didn't pay enough for a real c&l lol
BBK cai, 96 tbird maf housing, BBK 70mm TB, TFS intake manifold, BBK shortys, bassani off road X pipe, Flowmasters with turndowns
If any one is willing to donate parts to the Make Joe's Mustang Faster that Corvettes Foundation, donations will be gladly appreciated
Stockish302 is offline   Reply With Quote
Old 07-10-2012, 06:19 AM   #25
jdavis96gt's Avatar
Region: West Virgina
Where can u buy the screen at? I'd like to put one in mine. Previous owner took it out. I'd feel better with it in
Old 07-10-2012, 06:34 AM   #26
slow281
sixpac's Avatar
Region: Nebraska
It was wrecked pretty bad and the doner car was a gt.. So I an slowly returning it to a cobra..
2001 GT - True Blue
Old 07-10-2012, 07:43 AM   #27
Is the body shell the Cobra?
If not and it no longer has the Cobra VIN, it is no longer a Cobra, just a clone.
Old 07-10-2012, 08:36 AM   #28
slow281
sixpac's Avatar
Region: Nebraska
Yeah it was side swiped.. So the fender door and hood are from the gt red underneather.. And the ground effects on the driver side were ruined so he swapped them all because he wanted them to match..
2001 GT - True Blue
Old 07-10-2012, 08:41 AM   #29
Then you still have the Cobra VIN, so all you need to do is to restore the missing pieces.
Old 07-10-2012, 08:56 AM   #30
slow281
sixpac's Avatar
Region: Nebraska
So yes it's more like a cobra clone.. But once I get it painted I'm going to go badgeless so I guess it don't really matter..
---------- Post added at 09:56 AM ---------- Previous post was at 09:53 AM ----------
Yeah I'm buying the cobra ground effects.. I like the clean cut style more anyway.. Then I need the cobra intake.. And it should be back to normal.. Oh an the the front an rear axles need to be 5 lug again.. The front was damaged in the accident so he changed them both.. So at the moment is more like a cobra clone... Just got to work her back up.. Someday after school in like 4 years lol..
2001 GT - True Blue
06:04 PM
