Idle problems again.. - Mustang Evolution
Old 07-10-2012, 06:54 AM   #1
slow281
sixpac's Avatar
Region: Nebraska
T seams that I can't ever get my idle to drop.. I come up to a stop sign and throw it in neutral and my idle stays al like 1500rpm it takes anyware from 30 seconds to like two miniatures to drop. I'm stumped and do know ware to even start..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-10-2012, 07:34 AM   #2
Mikerod's Avatar
Re: Idle problems again..
have you checked the idle screw on the TB or the TPS? Usually the TPS goes bad
Mikerod is offline   Reply With Quote
Old 07-10-2012, 08:49 AM   #3
Read the articles about idle issues in the Useful Info Sticky threads.There are also some testing how to links so you can test the parts involved before you buy them.
Old 07-10-2012, 08:58 AM   #4
slow281
sixpac's Avatar
Region: Nebraska
I tried kinda but I think I was too frustrated to fully understand them lol. What is the TBS?
2001 GT - True Blue
Old 07-10-2012, 09:33 AM   #5
TPS = Throttle Position Sensor
There is also a terminology list in the Useful Info thread.
Old 07-10-2012, 11:07 AM   #6
slow281
sixpac's Avatar
Region: Nebraska
Well I guess I knew that I just me like ware is it and what's it look like?
2001 GT - True Blue
Old 07-10-2012, 11:52 AM   #7
Right there on top.
Old 07-10-2012, 01:11 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Right there on top.
Is there a way to clean that or do I just replace it?
2001 GT - True Blue
Old 07-10-2012, 02:16 PM   #9
Replace it.
Old 07-10-2012, 02:33 PM   #10
Travis B's Avatar
Trojan,
Should u replace the tps even if the voltage checks good? I have a 92 gt with the same idle problem. Still can't figure it out. I am pulling 17-18 of vac so I don't think I have a vac leak
Travis B is offline   Reply With Quote
Old 07-10-2012, 02:58 PM   #11
Originally Posted by Travis B View Post
Trojan,
If the voltage scales up and down smoothly when you open and close the throttle with the meter hooked up, then it should be ok.
Read the articles about idle issues and how to cure them in the Useful Info thread.
Also you need to follow the procedure in your Chiltons manual to reset the idle.
Do not just crank the idle screw up or down.
10:08 AM
