Smoke - Mustang Evolution
Old 07-10-2012, 12:21 PM   #1
1Mustang89's Avatar
Smoke
M blowing blue smoke every now and then. Not at start up but when it's warmed up. I hope it's nothing bad, the pipes are dirty maybe it could be all that getting hot?
1Mustang89 is offline   Reply With Quote
Old 07-10-2012, 02:55 PM   #2
aounds like you need to quit smoking.
unfortunatly blue smoke is usually a sign of burning oil.
how much oil do you use between oil changes?
you may want to do a compression check to insure your rings are good.
Old 07-10-2012, 04:48 PM   #3
1Mustang89's Avatar
I did an oil change almost 2 moths ago and I have put a quarter of a quart in since.
Old 07-10-2012, 04:53 PM   #4
that isnt to terrible i guess unless you dont drive much. i would do a compression test though.
Old 07-10-2012, 05:03 PM   #5
Re: Smoke
A puff of smoke on acceleration and deceleration is sometimes caused by bad valve seals and worn valve stems and guides.
Old 07-10-2012, 05:14 PM   #6
1Mustang89's Avatar
I drive it everyday, I hope it's something where I don't need a new motor
Old 07-10-2012, 05:16 PM   #7
if its valve seals it would need a head job. if its piston rings you in store for a full rebuild.
Old 07-10-2012, 05:17 PM   #8
1Mustang89's Avatar
Ya so either way I'm screwed
11:00 PM
