distributor - Mustang Evolution
Old 07-10-2012, 05:43 PM   #1
thomas91gt's Avatar
distributor
i was wondering if anyone could tell me which gear is on my 91 gt or how to tell the diff between the cast iron and the steel gears.
thomas91gt is offline   Reply With Quote
Old 07-10-2012, 07:00 PM   #2
Your gear should be steel as long as it still has the roller cam(which it should)
The cast is a rougher more porus finish.
Old 07-10-2012, 07:31 PM   #3
thomas91gt's Avatar
i pulled it earlier couldnt really tell a difference but its all orig stock roller motor so i was guessing steel to. my car acts like it has a rev limiter between 25-3000 good fuel pressure good tps reading so thinking maybe pip so i was gonna replace the dist any opinions??
---------- Post added at 07:31 PM ---------- Previous post was at 07:30 PM ----------
o and it backfires while engine is cold after it warms it idles good just no power
Old 07-10-2012, 07:34 PM   #4
Could be pip. But have you checked your timing? If your gonna replace you may as well upgrade to msd.
Old 07-10-2012, 08:05 PM   #5
thomas91gt's Avatar
i would but it is a 150$ difference lol kinda on a budget right now how common is it for these to jump time?
Old 07-10-2012, 08:09 PM   #6
then stick with the stock. i wouldnt go china or autozone special.
not common.
Old 07-10-2012, 08:20 PM   #7
thomas91gt's Avatar
yea i work at advance i can get one for about 50 i didnt think it was to common. this is driving me crazy i figure i would just put a distributor in it, hope for the best lol
Old 07-10-2012, 08:25 PM   #8
There is a procedure to check the pip. I don't recall if its in the Haynes or not. But I did see it online one time.
Old 07-10-2012, 08:29 PM   #9
thomas91gt's Avatar
yea the only one i have seen only tells if its sending a signal not how strong or how well it is working. mine runs so i know it is working somewhat. If this makes since lol
Old 07-17-2012, 10:33 AM   #10
thomas91gt's Avatar
Anyone know where i can get the connector u pull out to set the timing my buddy forgot to put it back in and its lost
Old 07-17-2012, 02:17 PM   #11
93slowstang's Avatar
Either a junk yard or you can order it from lrs.
http://www.latemodelrestoration.com/...ut%20connector
Old 07-17-2012, 02:24 PM   #12
thomas91gt's Avatar
Would it hurt to use a jumper wire till i can get one?
Old 07-17-2012, 03:14 PM   #13
Re: distributor
I don't know that I would use a jumper wire. I'm not sure that it is just a straight jumper. If you can verify that is all that it is then I suppose you could, but I've never seen one opened up.
That's probably why your engine does not run right.
The ECU cannot advance the timing with the spout connector out.
Old 07-17-2012, 04:16 PM   #14
You can use a jumper wire, or a fork terminal. All it does is complete the circuit.
Old 07-17-2012, 04:28 PM   #15
thomas91gt's Avatar
Yea it was the distributor replaced now does great but my friend lost the spout connector it had one before the install
Old 07-24-2012, 08:58 PM   #16
thomas91gt's Avatar
Anyone have an idea why my factory tach would be malfunctioning after I put a distributor in it. Its at 0 then if I start it, it's at 4000 its clearly not idling that high i would guess its actually around 900 then rev it up it barely moves it it might go up to 5000 Then it bounces when u turn it off
---------- Post added at 08:58 PM ---------- Previous post was at 08:56 PM ----------
O and I did get another spout connector from a fellow stanger
08:36 AM
