Amp light came on - Mustang Evolution
Old 07-10-2012, 05:54 PM   #1
89Saleen141's Avatar
Amp light came on
Just put in the 120 amp alternator and crank and water pump under drive pulleys plus a wire kit for the alternator. The install wasn't too bad, took way longer than i thought it would though. but when i started the car the amp light was on and the volts drop slightly over time? What did I do wrong?
89Saleen141 is offline   Reply With Quote
Old 07-10-2012, 06:37 PM   #2
its the under drive pullies.
---------- Post added at 07:37 PM ---------- Previous post was at 07:35 PM ----------
you could probably change the alternator pulley to a smaller and get a shorter belt.
imo they shouldnt even sell ud pullies for the fox. i think i have seen this problem at least 245,878,899,743 times
Old 07-10-2012, 06:44 PM   #3
Stang.racr's Avatar
You should have around 14 with a volt meter on the battery while running. How is the fuseable link
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-10-2012, 07:40 PM   #4
Re: Amp light came on
damn, i didn't even use the alternator pulley that came with the kit. Would it help to put the pulley off of the stock alternator onto the newer one?
Old 07-10-2012, 07:43 PM   #5
it may help. but you would probably have to change the belt to.
did you verify voltage like stangrcr suggests. that would help you verify your not charging good.
Old 07-10-2012, 07:46 PM   #6
I'm going to wait until morning, i'm off of work till saturday so hopefully i can get this resolved by then. I noticed that the water pump pulley didn't have a channel that the belt can sit on and was wondering if there was any way to ensure the belt will sit right on it?
Old 07-10-2012, 07:50 PM   #7
since the other pulleys still have a flange it shouldnt be able to slide. but just watch it a little bit.
08:51 AM
