Radiator leak - Mustang Evolution
Old 07-11-2012, 05:35 PM   #1
Sprague199's Avatar
Radiator leak
I Have a 87 gt it's leakin antifreeze not from the radiator but the bottom of car not sure if it's the hose or not anybody have any other ideas on what it can be before I go buy the hose kit
Sprague199 is offline   Reply With Quote
Old 07-11-2012, 05:37 PM   #2
Stang.racr's Avatar
Crawl under there and see where it is leaking from, if it's old I would just pay the 10 bucks and change the lower rad hose
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-11-2012, 05:52 PM   #3
Re: Radiator leak
That or it may be dripping out of the weep hole on the pump and hitting other under body components on the way down.
Old 07-11-2012, 06:03 PM   #4
Stang.racr's Avatar
Or this telling you it's time to change a water pump out. Pretty easy job as long as a EFFIN bolt don't break off :/
Old 07-11-2012, 06:20 PM   #5
Sprague199's Avatar
I've only had time to take quick glance when I start it and let it idle it doesn't leak but I take it down the road for short drive pull back in drive way and antifreeze just pours out
Old 07-11-2012, 06:26 PM   #6
Stang.racr's Avatar
Kinda confused but is it a small leak or more of a problem like running hot and boiling over after just a short drive?
Old 07-11-2012, 06:33 PM   #7
Re: Radiator leak
Is it coming from the overflow tube?
If so you may have a blown head gasket, cracked block or head.
Old 07-11-2012, 06:56 PM   #8
Sprague199's Avatar
Greeeeaaaat
---------- Post added at 06:56 PM ---------- Previous post was at 06:41 PM ----------
If it was head head gasket or block wouldn't it leak from the start the motor runs instead of just when it gets hot also oil isn't discolored
Old 07-11-2012, 07:03 PM   #9
Stang.racr's Avatar
Two warning signs of blown head gaskets could show a little water in your oil, you can check your dip stick and u would see a sheen, another way is removing your radiator cap and looking down. You can often see debris of a head gasket floating
Old 07-11-2012, 07:25 PM   #10
just a thought. if the cap doesnt seal properly it will let the water boil easier. when your system stays pressurized it is harder to boil the water. but without the required pressure the water will boil faster. if this makes sense?
Old 07-11-2012, 07:34 PM   #11
Stang.racr's Avatar
Yeah I believe the cap has to have a 10-12# seal. Not 100% sure on that number though
« Oil ? | KB S.C? »
10:39 AM
