valve springs - Mustang Evolution
Old 07-11-2012, 08:58 PM   #1
mystang50's Avatar
valve springs
Will valve spring off aluminium heads work fine on my iron heads??
Old 07-11-2012, 09:07 PM   #2
it doesnt matter what kind of head they came out of. just mattersmif they are the right type you need. pedastool, stud etc.
Old 07-12-2012, 12:21 PM   #3
Re: valve springs
Diameter and height must also match what is needed for your heads.
Old 07-12-2012, 02:04 PM   #4
Lol. I actually answered the question think rocker arms. was right before bedtime.
Old 07-16-2012, 12:35 PM   #5
mystang50's Avatar
Trickflow 170cc teistedwedge heads are the heads the springs are out of, will they work on my stock heads?? I keep floating a valve when motor is cool, stock springs with e-cam
Old 07-16-2012, 02:29 PM   #6
I'm not sure on that one bud. I would call trickflow to be safe. Or just make sure they are the same size then they should be ok.
Old 07-16-2012, 02:34 PM   #7
Re: valve springs
Just measure and compare the diameter and height with a pair of calipers.
Then check for coil bind after you have installed a pair on the head.
I'm going to hazard a guess that they are different.
11:47 PM
