My new harmonic balancer does not have timing marks like my old one did! - Page 2 - Mustang Evolution
Old 07-14-2012, 02:17 PM   #36
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Originally Posted by dreamstang
you have stock rockers? i dont remember the procedure for tightening them.
Stock rockers you just tighten them down, don't remember the torque spec off hand
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 07-14-2012, 02:22 PM   #37
i thought so. i dont remember either maybe something like 20lbs ish but i could be wrong.
Old 07-14-2012, 02:24 PM   #38
Pete Jones
Yeah, I'd say 20-30lbs sounds about right. Can't remember what mine were when I swapped heads and it's only been a year heh.
90 LX hatchback
89 LX Notchback
Old 07-14-2012, 02:25 PM   #39
passenger side is the same way. Would all o those being loose cause oil to flow to the intake and exhaust?
JayKranz is offline   Reply With Quote
Old 07-14-2012, 02:28 PM   #40
idk. this is a good one for trojan! trojan help help
i dont think that it would cause that but maybe with the valves floating? idk
Old 07-14-2012, 02:28 PM   #41
Pete Jones
How loose we talking? Like u can take the bolts outta the rockers by hand or can just slightly wiggle then back and forth?
And I agree with dreamstang, I don't think it would cause it but I'm not certsin
90 LX hatchback
89 LX Notchback
Old 07-14-2012, 02:56 PM   #42
wiggle a bit
---------- Post added at 03:56 PM ---------- Previous post was at 03:47 PM ----------
Should I take the lower intake off and check the lifters or just tighten the rocker and put it back together.
Old 07-14-2012, 03:02 PM   #43
im to the point where i dont want to guide you in the wrong direction. because i am only a diy'er with only experience that i have done personally. and i know the problems that you have been through, so i get a bit nervous.
but first im curious to know why the rockers where loose. did you tighten them down the first time to the procedure listed in your manual?
something else that comes to mind. if your lifters sat for a while they may have needed to be primed and/or soaked in oil. or did you use new lifters?
Old 07-14-2012, 03:04 PM   #44
I used the ones that sat for awhile and did not prime them. I f'ed up didn't I? Do u think if I take the lower intake off they would still be good? I still have my stock ones too.
Old 07-14-2012, 03:10 PM   #45
this is where im not sure. maybe after running they will prime, im not sure. i think it will be ok once they get enough oil in them. but you will have to check to make sure they are tight a few times. its always hard saying, because sometimes if a lifter sits it wont need prime and sometimes it will. i am just not sure if you need to pull them or not, and if they will pump up them selfs or not? idk
i do know for sure if they dont have oil in them they will change in size, throwing off you tightening them.
thats why most people usely dont take a chance and just prime them to be safe.
Old 07-14-2012, 03:12 PM   #46
I'm gonna use my old ones and see what happens, but could bad lifters cause oil to go everywhere? Would that be possible?
Old 07-14-2012, 03:20 PM   #47
i dont think they could. but not sure. darnit we need teojan back on! lol
usually oil in the intake is caused from crank case pressure. most cases the pcv system is at fault.it is also more common on a forced induction motor. some people install an oil seperator on the pcv. and as i have seen trojan just recently pick up a pump to vacuum out pressure from his crankcase.
if ou take your pcv off is there lots of oil in it? that might tell us if this is whats going on.
Old 07-14-2012, 03:28 PM   #48
I dont think that's it. My car was at idle. no boost. also it's vented to atmosphere after the last set of head gaskets
Old 07-14-2012, 03:35 PM   #49
im not sure then. i dont see any other way for the oil to get into the intake.
Old 07-14-2012, 03:36 PM   #50
Okay, maybe u r right. I'm almost done taking it apart now. Lower intake will be off shortly
Old 07-14-2012, 03:42 PM   #51
i wouldnt put it back together right away. i wold let whatever lifters you are putting in soak in oil over night. or you maybe able to pump them with an oil can.
im still not positive you needed to take it back apart. as they may have pump up themselves. but not sure cause i like to play it safe and do it ahead of time.
Old 07-14-2012, 03:43 PM   #52
all I know is that I have oil in funny places
---------- Post added at 04:43 PM ---------- Previous post was at 04:42 PM ----------
started making serious noises plus the whole oil everywhere issue
Old 07-14-2012, 03:58 PM   #53
thats about all i know to. lol oh and its not good, you just have to bare with me a little cause im no expert and its somewhat difficult trouble shooting over the net.
---------- Post added at 04:58 PM ---------- Previous post was at 04:44 PM ----------
i hope it works out man. im keeping my fingers crossed!
Old 07-14-2012, 03:59 PM   #54
thanks
Old 07-14-2012, 04:06 PM   #55
re: My new harmonic balancer does not have timing marks like my old one did!
Originally Posted by JayKranz View Post
No coolant but just took my upper intake off and there is lots of oil in it?
Who put the engine together? I wonder if the rings were installed correctly or if they are the correct rings?
Just tighten them down to specs, there is no adjustment.
Old 07-14-2012, 04:08 PM   #56
would the rings would allow oil alll the way into the intake?
Old 07-14-2012, 04:08 PM   #57
I machine shop in Addison IL supposedly. It's the DSS 331 kit and it comes with the rings. There's no coolant in my oil btw. I have lower intake off and really don't see anything wrong.
Old 07-14-2012, 04:14 PM   #58
Yes they will.
Worn, incorrect or improperly installed rings cause blowby and will push oil into the intake.
Old 07-14-2012, 04:16 PM   #59
I'm afraid you are going to have to tear it down to see what the issue is.
Hopefully not, but that's sure what it is beginning to sound like.
Old 07-14-2012, 04:20 PM   #60
when you say tear it down do you mean pull the engine again?
---------- Post added at 05:20 PM ---------- Previous post was at 05:17 PM ----------
it's brand new everything including the block. Isn't there a break in or something? Man I'm dyin here
Old 07-14-2012, 04:20 PM   #61
he could do a compression test first to verify first right?
Old 07-14-2012, 04:22 PM   #62
I'll do it if I have too
---------- Post added at 05:22 PM ---------- Previous post was at 05:20 PM ----------
I already have all but the heads off, it did however blow my finger off the spark plug hole when trying to find tdc.
Old 07-14-2012, 04:24 PM   #63
that is compression, but not an accurate compression test. i dont remember for these engines, but you need to use compression gauge. and all cylinders should be something like 150 lbs and not vary more than 10 lbs.
Old 07-14-2012, 04:43 PM   #64
Yes, there is a break in period, but if your lifters are not pumping up (loose) and you are getting that much oil in the intake and exhaust something doesn't sound right. Hopefully it is nothing serious.
Hey, maybe they just pumped the cylinders full of oil to preserve them?
I really feel for you and I wish I could help you out more.
Old 07-14-2012, 04:44 PM   #65
Yes, definitely.
His Chiltons should give the specs.
Old 07-14-2012, 04:50 PM   #66
so should I just try soaking the lifters for a day then putting it all back together?
---------- Post added at 05:50 PM ---------- Previous post was at 05:49 PM ----------
can I do a compression test with the upper and lower intake off?
Old 07-14-2012, 04:55 PM   #67
That would probably be a good idea. Use a lifter to try and work the hydraulics up and down while they are in the oil if you can.
You really need to have the engine warmed up to operating temp to do a compression test.
If it is cold the readings will be off considerably.
Old 07-14-2012, 05:23 PM   #68
Do u mean just push the top in with my finger or the pushrods? Manually in the oil bucket?
Also, I did have about a half quart of oil in my upper intake. Sounds like blow by right?
---------- Post added at 06:23 PM ---------- Previous post was at 06:13 PM ----------
Would the failed lifters allow oil to pass through areas it wouldnt normally pass?
Old 07-14-2012, 05:28 PM   #69
Manually in the bucket, with a pushrod. Just to work the air out.
That's a lot of blowby. I bet they filled the cylinders with oil like I wondered above.
Old 07-14-2012, 05:29 PM   #70
Forum Car Trader
90GTNovi2000's Avatar
Dammit JAY!!! Wish you could avoid some of the bad luck.
90GTNovi2000 is offline   Reply With Quote
07:58 PM
