My new harmonic balancer does not have timing marks like my old one did! - Page 5 - Mustang Evolution
Old 07-16-2012, 08:47 PM   #141
hmmm... so your saying you have what, 1/8" or less?
Old 07-16-2012, 08:48 PM   #142
Probably
JayKranz is offline   Reply With Quote
Old 07-16-2012, 08:55 PM   #143
can you clay the pickup? just put something over the scree so you dont get clay in it. then bolt the pan up. then take it off and measure the clay. i dont think clearance is an exact science but if its to close you may not flow good.
Old 07-16-2012, 08:57 PM   #144
Will do. I also bought a new pump.
Old 07-16-2012, 09:02 PM   #145
cool. hopefully that could have been your problem but it hard saying. we' ll see exactly what you had and go from there.
Old 07-16-2012, 09:02 PM   #146
Okay
Old 07-16-2012, 09:05 PM   #147
i have a feeling these guys still might think its worth pulling the pistons just to be sure to. you are already this far. but check your clearance and see what the other guys think to.
Old 07-16-2012, 09:16 PM   #148
Really, pull the pistons even with decent compression? I'll do whatever at this point but I was hoping not to pull my heads again.
Old 07-16-2012, 09:19 PM   #149
maybe not, since you have good compression. i would think the rings are sealed if the compression is good. im guessing trojan may have a good diagnoses with your new imformation.
---------- Post added at 10:19 PM ---------- Previous post was at 10:19 PM ----------
i wouldnt want to replace a head gasket again either.
Old 07-16-2012, 09:23 PM   #150
Haha it's all adding up;$
Old 07-16-2012, 09:24 PM   #151
the only thing that still confuses me is how much oil you had in the intake. i just am not sure if that could or could not happen from the lifter.
Old 07-16-2012, 09:33 PM   #152
Me either, TH where are you?
Old 07-17-2012, 08:12 AM   #153
Re: My new harmonic balancer does not have timing marks like my old one did!
Originally Posted by JayKranz View Post
I have no where near that! Probably part of the problem. It looks like my pick up tube is on the bottom on the pan. The pan depth is 7.25, and the pick up is very slightly less than that.
Use some Play Doh to check your pickup screen clearance and that 1/4" I typed into the PM I sent was supposed to be 1/2" to 3/8".
I set mine at 3/8" from the bottom of the pan to the edge of the screen as the screen itself is usually a bit higher.
Old 07-17-2012, 08:15 AM   #154
Sorry guys. Zonked out from pain and nerve meds.
I put off taking that stuff until I just can't stand the pain any longer, because 30-45 minutes after I do, I usually crash.
I hope I answered your questions in the PM?
Old 07-17-2012, 08:16 AM   #155
Sorry man, that really sucks!
Old 07-17-2012, 09:40 AM   #156
Thanks Jay I appreciate your concern.
It's not pleasant to say the least. What bothers me the most is the loss of strength and most of the use of my right arm/hand. Without it, working on my ride is going to be difficult, but I will persevere!
Old 07-17-2012, 09:43 AM   #157
Where in MO are you?
Old 07-17-2012, 09:46 AM   #158
Almost the center of the state, Fayette.
Old 07-17-2012, 09:49 AM   #159
Ah pretty far for me, maybe 7-8 hours.
Old 07-17-2012, 09:56 AM   #160
Yeah, that's an issue for all of us hard core Fox Body fans.
I have my nephews lined up to do the heavy lifting and wrench pulling, if they can stand dealing with my obsessiveness in getting everything perfect that is.
11:42 AM
