My new harmonic balancer does not have timing marks like my old one did! - Mustang Evolution
Old 07-12-2012, 08:03 PM   #1
ow do I identify base timing with this balancer? It says 90,180,270,360
---------- Post added at 09:03 PM ---------- Previous post was at 09:01 PM ----------
I think it's at tdc now, but????
JayKranz is offline   Reply With Quote
Old 07-13-2012, 05:51 AM   #2
re: My new harmonic balancer does not have timing marks like my old one did!
It doesn't have the degrees mapped out on the side? Usually 0-30 or so.
90 is 90° from TDC. It's marked that way to simplify valve adjustments and whatnot.
Old 07-13-2012, 05:55 AM   #3
Oh, in the case I'm still confused on how to find my 10 degree stock base timing. It is at tdc now.
---------- Post added at 06:54 AM ---------- Previous post was at 06:53 AM ----------
I'm trying to get it started this morning. I'm sure this is not hard I've just never done it and am having a serious brain fart.
---------- Post added at 06:55 AM ---------- Previous post was at 06:54 AM ----------
slight surface rust maybe I'll steel wool it.
Old 07-13-2012, 06:01 AM   #4
Just advance the distributor a tiny bit, snug it down and start the engine. You will need to do the final adjustment with it running, using a timing light.
P.S. It is confusing and a bit hard to learn when you are doing it for the first time.
Old 07-13-2012, 06:02 AM   #5
Advance = Clock wise?
Old 07-13-2012, 06:05 AM   #6
Counter Clockwise
Always in the same direction the distributor turns. When you advance you are making it fire sooner than it normally would.
Old 07-13-2012, 06:07 AM   #7
Okay
Old 07-13-2012, 06:08 AM   #8
Good luck!
Old 07-13-2012, 07:44 AM   #9
I know your firing it today. But I have some timing tape. It's made to put on the crank so you can see the marks very well. I can send it to you for free if you want. But it may take a few days to get. Or a local speed shop may have it.
If you can't read the marks you won't be able to time it. If you cann see them a little, you maybe just able to use a paint stick or something and mark the 10* btdc on the crank. Then when your light is flashing you can just line it up to the paint stick mark.
Old 07-13-2012, 08:56 AM   #10
I used steel wool and can barely see it. Thankyou
Do I turn it to 10btdc(left of zero) then drop the distributor in?
Old 07-13-2012, 09:15 AM   #11
The mark will be before top dead center. So when you turning crank clockwise you will stop before 0, which will be to the right of 0.
Mark you 10 mark like I mentioned with something before you time with a light like I mentioned. It will help tremendously.
Old 07-13-2012, 01:21 PM   #12
Can't get it started! I'm sure I'm doin the timing wrong. How do I get back to tdc when the engine is in the car? I can't turn the crank anymore?
Old 07-13-2012, 01:37 PM   #13
The crank is just harder to turn since the spark plugs are in. You can still.turn it over but it take a lot of force. You can either have someone bump the starter while you watch, or take the plugs out.
You need to be on tdc on compression stroke. If you hold your finger over the #1 spark plug hole and turn the motor over, you can feel the compression. It will blow a lot of air out of the hole. When that happens you are on the right stroke. Then continue to your mark after you feel the compression.
Old 07-13-2012, 01:46 PM   #14
What do you mean you can't turn the crank?
You have to rotate the crank to where the #1 cylinder is coming up on the compression stroke and set it to TDC at the timing pointer. Try to not go past TDC. If you do you have to make a couple of more turns to get it back up to TDC. Do not go backwards with the crank when setting the initial timing.
Hahaha! I started typing that then got distracted. looks like you beat me to it.
Old 07-13-2012, 01:50 PM   #15
I'm just gonna go fishing for awhile and come back to it. Just frustrated.
Old 07-13-2012, 02:11 PM   #16
Sometimes that's the best thing to do. Re gather your thoughts. Good luck man. You'll get it.
---------- Post added at 03:06 PM ---------- Previous post was at 03:05 PM ----------
Also I forgot to mention. A common mistake is people use the wrong firing order. I forget the year of your car but I'm sure its a newer fox and you need the HO firing order.
---------- Post added at 03:11 PM ---------- Previous post was at 03:06 PM ----------
Haha. I quick drawed ya.
Old 07-14-2012, 05:29 AM   #17
Okay starting over from scratch. I got a timing gun that has a dial on it. So I seethe car at 0(TDC), then I set the dial on the gun to 0, or to 10?
Old 07-14-2012, 05:38 AM   #18
I'm not big on those dial guns and not very experienced with them. But I am pretty sure the way you use them:
Set the dial at 10 then it will flash on the 0. Which means you want to see 0* on the crank when its strobing if the dial is on 10.
Old 07-14-2012, 07:37 AM   #19
Hey jay. If you still are confused about the timing. Get on YouTube.msd has some really nice videos on there that explain the whole process very nicely. I forget what they are called, but may install distributor, or set timing. But you wanna watch the msd videos. They will go step by step, the whole process.
Old 07-14-2012, 12:15 PM   #20
Got it fired! Timing was 180 off. Next problem it's blowing a lot of white smoke and some oil is coming from the exhaust.
Old 07-14-2012, 12:22 PM   #21
White smoke could mean water.
It could be left over junk from assembly. I would let it idle a bit and see if it clears up.
Also don't romp on it till u retune it!!!!!
Old 07-14-2012, 12:28 PM   #22
There is some oil in my exhaust?
Old 07-14-2012, 12:34 PM   #23
Is there? If there is give it a few and it may clear up. Usually on my first fire up I get some smoke. If it doesn't clear up then you'll have to investigate.
Hopefully you head gasket sealed.
Old 07-14-2012, 12:38 PM   #24
I used FelPro 9333pt1
Old 07-14-2012, 12:38 PM   #25
I think that's what I used but I don't remember. Did you use thread sealant on the head bolts?
Old 07-14-2012, 12:40 PM   #26
Yes studs
Old 07-14-2012, 12:42 PM   #27
How long did you let it run?
Old 07-14-2012, 12:46 PM   #28
2 minutes and then got nervous. About 1cup in my turbo hot pipe coming from exhaust.
Old 07-14-2012, 12:57 PM   #29
It's hard saying bud. The best way to check would be to pull a valve cover or if you can just look in an oil fill and breather. Then see if you can see anything.
Then the other check would be a compression test.
It's still hard for me to tell. Sometimes they do smoke a bit on first fire up for a few minutes though.
That's all I got. Hopefully everything good.
---------- Post added at 01:57 PM ---------- Previous post was at 01:52 PM ----------
Also check your oil and coolant to make sure they aren't mixing. But I'm not sure if 2 minutes would be enough to in know or not. But easy check.
Old 07-14-2012, 01:21 PM   #30
Making valve train noise now
Old 07-14-2012, 01:43 PM   #31
That and the other issues do not sound good.
How is the oil pressure and is it contaminated with coolant?
Old 07-14-2012, 01:59 PM   #32
No coolant but just took my upper intake off and there is lots of oil in it?
Old 07-14-2012, 02:05 PM   #33
do you have you pcv and screen for it in place?
Old 07-14-2012, 02:09 PM   #34
yup, I just got the passenger valve cover of and all but one of my rocket has play
Old 07-14-2012, 02:14 PM   #35
you have stock rockers? i dont remember the procedure for tightening them.
06:23 AM
