need help with an automatic transmission of a ford mustang 1989 - Mustang Evolution
Old 07-14-2012, 02:33 PM   #1
Ojpt's Avatar
The transmission didn't change
And also i need the automatic transmission overdrive specifications
Ojpt is offline   Reply With Quote
Old 07-14-2012, 04:50 PM   #2
Re: need help with an automatic transmission of a ford mustang 1989
Ok, Not real sure of what you need here.
What do you mean "didn't change"?
If it is not shifting, then you may have valve body problems.
What "specs" are you looking for?
If you are wanting overhaul info, you will probably have to buy a manual as there is just too much info in them to post up here.
Old 07-14-2012, 05:49 PM   #3
Ojpt's Avatar
Exactly. It is not shifting
---------- Post added at 05:43 PM ---------- Previous post was at 05:41 PM ----------
Yeah it is overhaul info. Can you tell me a good website or somewhere to buy that manual?
---------- Post added at 05:47 PM ---------- Previous post was at 05:43 PM ----------
Also it has a plug that i don't connected. I don't know if that have relationship with that is not shifting
---------- Post added at 05:49 PM ---------- Previous post was at 05:47 PM ----------
And i don't know if that transmission has a vaccum
Old 07-14-2012, 07:33 PM   #4
I don't know much about them, but if the TV cable isn't set correctly it can cause shifting problems and ruin the transmission fairly quickly.
As far as vacuum, I'm just not sure. Check and see if it has any lines going to it.
Ford AOD Rebuild Manual
Old 07-14-2012, 07:38 PM   #5
Forum Car Trader
90GTNovi2000's Avatar
+1 on the tv cable/ kickdown or junk in the valvebody.
90GTNovi2000 is offline   Reply With Quote
Old 07-14-2012, 08:06 PM   #6
Ojpt's Avatar
Ok. Thanks trojan horse
And thanks 90GtNovi2000
Old 07-14-2012, 08:08 PM   #7
You're Welcome & Good Luck with your project.
Old 07-14-2012, 08:19 PM   #8
Ojpt's Avatar
Thanks
07:40 AM
