Whats next?? - Mustang Evolution
Old 02-25-2008, 10:10 PM   #1
Whats next??
Well being a newbie..I started just buying parts and putting them on but now I dont know whats next?? I have Mac cold air intake,Professional Product 70mm TB(not put on yet), March underdrive pullies,aluminum radiator with electric fans, NGK wires and plugs, BBK longtube headers, H-Pipe, and Flowmaster catback, aluminum driveshadt, 3.73 gears. What do I buy next?? My end goal is a 11.50 car with either turbo,supercharger,or nitrous as a power adder. So guys..What now??? Thanx for helpin' a clueless guy out!!
Jay Rod 5.0 is offline   Reply With Quote
Old 02-25-2008, 10:48 PM   #2
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
Re: Whats next??
engine work next, weight reduction (if real serious anout dragin), what year?
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 02-26-2008, 07:03 AM   #3
MonteCitan's Avatar
Re: Whats next??
as typical as it sounds...
heads/cam/intake
perhaps a nice set of AFR 165s (unless you're planning a new bottom end or boost, 185s might be better) a matched cam, and one of the better intakes, edelbrock performer II or along those lines...
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-26-2008, 08:43 AM   #4
Re: Whats next??
I'm a real newbie at this mustang stuff (89' GT)..what cam...I saw the AFR 165 heads on BrotherPerformance for $1387.95. What else do I need to put these on..or do I use my old parts...what about fuel and spark...I'm pretty much stock.??...
Old 02-26-2008, 09:45 AM   #5
wiarumas's Avatar
Re: Whats next??
i vote engine work as well... since you plan on getting it blown in the future.
Old 02-26-2008, 10:01 PM   #6
Re: Whats next??
if you are going to go blown in the future I would get some head studs from ARP. You can torque them tighter to prevent blown head gaskets. Depending on what you do now, you will need bigger injectors and a calibrated MAF. You should not need to worry about spark till blower.
Old 02-27-2008, 03:22 AM   #7
Re: Whats next??
This is what I'm thinkin' Trick Flow Track topend kit, someones shortblock complete(any suggestions?),C&L 73mm calibated to 30lb injectors and 255lb. fuel pump. I have underdrive pullies...are they going to be a problem??
Old 02-27-2008, 09:01 AM   #8
Re: Whats next??
I dont have any personal experience with C&L but I have heard they are crappy too many times. your UDP are okay for now, but when you go blown you will want to return to stock to get the right ratio out of your supercharger. if you go turbo they will be fine.
Old 03-10-2008, 09:25 PM   #9
silverstangboy's Avatar
Re: Whats next??
C&L doesn't work good as a MAF voltage modifier... as a standalone MAF with a tuner (like tweecer, PMS) they work just fine... sooo, tuner=fine no tuner=bad...
if your going to try to avoid doing your own tuning definetly look at a Pro-M as an option, if your going to do your own tuning i'd look into a ford mas of some sort. like a 90mm Lmaf in my case.
165's will be decent heads for a 6K rpm 302 with the right supporting parts, make sure and buy them bare and put good valves, locks, retainers, and for sure studs, the AFR studs are absolute crap, i've broken 3 of them.
185's for a 302 if you'd like to turn the rpm's up a bit..
but in all honesty im just shooting from the hip until you can tell us more about what your goals are.
93 mustang notch
~450hp 331 stroker - Sold
Old 03-11-2008, 02:23 PM   #10
Re: Whats next??
I just want a full weight 89' GT that turns mid 11's..
Old 03-13-2008, 10:02 PM   #11
Re: Whats next??
you will need more advanced help than mine, I will admit that. check out hardcore50 and SBFT.com those guys can get you there, expect to break the bank though... no cheap way to do what you want.
93 mustang notch
Old 03-14-2008, 12:52 AM   #12
MonteCitan's Avatar
Re: Whats next??
Not true silverstang he'd be close with what he's planning and a solid bottom end, hell you should be close to 11s.. But sledge, if you want solid mid or low 11s, go AFR 185s minimum and a cam/heads/intake that will take advantage of it, heck 306s with the right heads/cam will run 11s but most likely not at stock weight
also expect to fully upgrade your rear, new gearing, better axles, and trans as well
Old 03-14-2008, 10:19 PM   #13
Re: Whats next??
he wants to do it in a full weight GT, that would require alot more engine/tranny/suspension than my current setup.
if money wasn't a concern though, i'd do a big piston stroker dart! have fun! and shoot for 10's
93 mustang notch
Whats Up Whats Up From Georgia ShesmuRa New Member Introductions & Greetings 6 11-02-2009 02:23 PM
whats up mustanglvr New Member Introductions & Greetings 11 04-16-2009 07:18 AM
Whats Up? my98stang1 New Member Introductions & Greetings 16 01-21-2006 01:21 PM
Whats the most... damustangfan14 The Bar 13 09-28-2004 05:19 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 10:24 PM
12:36 PM
